Question about Proscan Televison & Video
I replaced the mainboard on my proscan TV, but the picture still won't show, what's wrong?
I have a Make Proscan Model plded4079sm Part# 186313 Serial # a1604167270001772. The TV will not turn on. The red light on the lower right side of the TV will blink 7 times when I try to turn the TV on. When I try to turn it on again the light disappears until I press the on button again. I read in a few places that if the TV doesn't turn on it's just an issue with the power supply and to just replace that part. This TV has a main board that has everything connected to it the power supply, the hdmi ports, EVERYTHING. So, I replaced it, but it still does not work.
  • deton8 von Splosion May 03, 2017
    Sorry... Should have STARTED with telling you to restore your GOOD main board...
    date and note your install o the :SPARE".
  • Proscan Master
  • 3,197 Answers
Hello Anonymous,
By putting your number (plded4079-sm) on eBay... immediately produced no "USA" power boards...
Likewise an AMAZON search failed.
Which means most FIXYA volunteers are going to
have some difficulty ... The number of your PROSCAN are the only thing that DIFFERENTIATES your set from our similar USA (domestic) models...
We just call them "power boards"... and they are popular
because the new industry standard for capacitors is
"cheap & cheesy"...
The bright-side = there is a bounty of "SPARES" on eBay...
and their reliability (& reputation) is NOT much worse...
(I'm just saying) Shop around...!!
Cautionary statements:
You MUST VERIFY your own circuit pack numbers
(stare & compare)...
Get and use ESD (electro-static Discharge) wrist straps while handling EVERY CIRCUIT BOARD you care about.
(see below)
Take lots of pictures going in... Put EVERY wire
EXACTLY back from whence it came...
and... FORCE NOTHING.
PS50B450B1WXXU = UK
PN50C450B1DXZA = USA (wrong)
Failed searches
http://www.shopjimmy.com/proscan/plded4079-sm
http://www.searspartsdirect.com/model/search.html?q=plded4079-sm
ESD wrist strap
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Carnac the Magnificent
Posted on May 03, 2017
  • 6 Answers
SOURCE: Viewsonic N3250W no power light ?
check out this website, it's got everything you need. I have to give all the credit to Alain, a brilliant guy in France who dug in and solved the problems. he gives instructions for the professional to fix the problem, but he also gives the sources for the power supply board to be purchased and for the little chip that causes most of the problems. I decided to take a risk and save some money and bought just the chip for $20 and very carefully soldered it in after removing the old one. The tv is fine a month later. The board comes out with no soldering, just some quick connectors and the back of the tv will come apart after you remove all the screws and the base by gently prying the back case from the front bezel along the sides of the tv. if you look closely, you will see the small cavities to pry from.
here's the website:
http://pagesperso-orange.fr/alain.mionnet/enii3210j.htm
Posted on Aug 06, 2008
  • 41 Answers
SOURCE: Shuts off
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Posted on Feb 25, 2010
  • 8457 Answers
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Posted on Jun 22, 2010
SOURCE: TV power light blinks 7 times and won't turn on
your sc bord is shot replace board and do firmware upgrade will coast about 400
Posted on Dec 17, 2010
Diagnosing tv auto shut down.
The TCON board is not junk, if anything it is the mainboard that is faulty.
Jul 04, 2016 | Proscan 40LD45Q TV
I have a proscan tv model ps20105 an it does not work .......how can I begin to seek the fail?
the tv keeps going black i an still hear the tv its just no picture it show a picture for like 6 seconds then cuts off
Jul 02, 2010 | Proscan PS20105 TV
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Feb 17, 2009 | Proscan 32LA30Q Television
Proscan PS61700 Beeping no picture
I have a 60in Proscan Projection TV. My picture is out and the TV only beeps.
Brian Allen
Feb 03, 2008 | Proscan PS61700 60 in. Rear Projection...
No picture
may I ask first if ur TV has a raster...
Jan 29, 2008 | Proscan 32LA30Q Television
PROSCAN PICTURE IN PICTURE DOES NOT WORK
You can't receive two pictures at the same time on your Satellite Receiver. I have the same tv with Dish.
Dec 13, 2007 | Proscan PS61670 61" Rear Projection...
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Proscan ps27108
are you changing the input to see it picture? have you connected the red input plug to the side of the tv?
Sep 09, 2007 | Proscan 19LA25Q 19 in. LCD Television
Televison & Video Logo
32 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
