Question about Ecoquest Air Purifiers
After replacing the fuse on my ecoquest air purifier . it went on. turned it off again and it would not come on when I tried a few minutes later.
Cerfer39
  • 709 Answers
SOURCE: replacing uv lamp in Ecoquest air purifier
Hi FCfogl, Here's you answer. Go to the URl below for detailed instructions with pictures. http://www.airpurifierrepair.com/PageInfo.aspx?page=ReplaceUV Hope this helps
Posted on Sep 26, 2007
SOURCE: ecoquest air purifier uv lamp replacement
Changed my purification plate and when I started the unit back up it just would start the fan and then shut down in about 7 seconds. It will restart the same process, but will not stay running. The fuse looks good, and it is making the filter switch can anyone suggest the next idea
Posted on Dec 22, 2007
SOURCE: Living Air Purifier (Flair Model) Ecoquest
Pull the unit out of the box and flip it upside down. You should see it
Posted on Mar 16, 2008
SOURCE: Ecoquest FreshAir - UV Flickering
Need change the whole RCI cell since the u.v light is inside the RCI cell.
Posted on May 23, 2009
Dutch7773
  • 31 Answers
SOURCE: No power is getting through to unit.
I have seen it a couple of times where the cable was not properly seated into the back of the machine. If you wiggle the connector, does that make any difference? If this works, then call EcoQuest for an RMA. Is the machine still under warranty? There is a 3 year warranty on FreshAir units, if purchased through an official dealer.
Dutch
Posted on Jul 23, 2009
What can I do for two Ecoquest fresh air 2.1 that both flicker on start up?
It doesn't sound fixable in the field. It may be a control panel issue. Contact Vollara (which bought Ecoquest) & get through to tech support. 800-989-2299.
Apr 27, 2014 | Ecoquest Fresh Air Air Purifier
My ecoquest fresh air turned off suddenly... when i turn it on again there is no power it keeps flashing in the front screen .. is it an easy fix or hard fix ? please advice ... thank you
Oct 11, 2010 | Ecoquest Fresh Air Air Purifier
Ecoquest Purifier was working when I went to work. When I returned, it was not running and would not start
Hi.
The RCI Cell must probably be replaced, this must be done about every three years. Ecoquest has no website or online support. You can get support calling the number listed on the manual below.
The part costs about $90, parts available here.
Replacement is explain at page 15 in manual available here.
There is also a debate on health concerns related to ionized air purifiers. Here Ecoquest answer, stating the product is safe.
On the other hand:
The Dangers of Ionic Air Purifiers
Ionic Air Cleaners
Please read also this article.
Before replacing any part I suggest to read the articles. Ozone related concerns have caused the recall of other similar devices.
Regards.
Ginko.
Aug 25, 2010 | Ecoquest Fresh Air Living Air Purifier
Ecoquest Fresh Air Air Purifier turning itself off and on rapidly
There is a problem with the main circuit board. Ecoquest will replace the circuit board. If the Fresh Air is still under warranty you have to pay shipping. If it is not under warranty, you'll have to pay all of the repair cost. You'll need to call to get an RMA number before you send it in, either way.
Dec 07, 2009 | Ecoquest Fresh Air Air Purifier
I have the same thing so ordered new ozone plate,
try soaking the plate for a few minutes in ammonia ...it will bring these back to life
Jul 01, 2009 | Ecoquest Breeze AT Living Air Purifier
Purifier doesn't go on and keeps blowing fuses when turned on
If the machine keeps blowing fuses there is a short in the electrical circuit and it needs to be looked at by a certified repair center.
Make sure the fuses you replace are the same as the original
100,110 volt models use the 1.0 amp slow blow fuse
220 volt models use the 0.5 amp slow blow fuse.
I hope this helps
Eric
Jan 10, 2009 | Ecoquest Breeze AT Living Air Purifier
Away mode broke my fresh air by ecoquest
There could be a couple issues at play here.
1) The power cable might not be plugged in correctly.
2) The fuse might be blown
3) there might be another electronic failure.
1 and 2 are pretty easy to check. Go to www.healthylivingia.com and look for the FreshAir, under the support tab you will find manuals that you can print out.
For the third option you would have to send it in. An authorized repair center needs to take a look at the machine and diagnose the problem. You can call EcoQuest at 1-800-989-2299 to find out where the closest repair center is.
I hope this helps.
Eric
Dec 28, 2008 | Ecoquest Fresh Air Living Air Purifier
EcoQuest Fresh Air Lamp replacement
Its probably the starter. Manual says to replace both lamp and starter at same time.
Jul 19, 2008 | Ecoquest Fresh Air Air Purifier
Air Purifiers Logo
127 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Kory Ronning
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
