Question about Kitchen Ranges
I ve just visited elderly people who are in a cottage with a Stanley No 8 range .....the oven is not heating Is there a open/shut valve or anything which needs adjusted ??
SOURCE: adjusting the oven door hindges for a snug fit
i wanna circuit board of inkjet printer and faluts finding
Posted on Dec 19, 2007
Treefrog15
  • 127 Answers
SOURCE: ERROR CODE # F6E1 displays and shuts down oven
F6-E1 - Return Line Not Connected - Replace control board (clock).
Posted on Dec 23, 2008
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
aborcass
  • 2651 Answers
SOURCE: oven temperature adjustment
well no need to fret, if you oven is heating over 100 degress off theres problably not an adjusatment to compensate for that, youll need to either replace the htermostat or the thermistor, depending on which your machin uses
Posted on Jan 20, 2009
  • 52 Answers
SOURCE: 5/8 flooring nailer
TJ
The flooring is it engineered or solid? Specific engineered can be nailed with this gun. Using hte white plate that came in the bag, Its a thicker plate than the gun, and a BOSTITCH 108771, metal shim that installs inside the gun. This will allow 5/8" thick, Owens, Aswaha bay, etc 5/8" thick, with a heavy wearlayer to be installed with this nailer. Any thinner wear layer will become a problem
Posted on Mar 02, 2009
I have a stanley brandon 80k oil range style cooker. The Hot water and oven work fine but the heating intermittently does not work when either set to come on via the timer or via pushing the override...
Sounds like you have a valve sticking or a safety switch causing it to shut down. Does this unit exhaust first then the burner ignites that might be your issue
Jan 09, 2015 | Ovens
Oven pilot comes on but oven will not lite, burners work
The reason the oven ogniter will come on yet their is no heat in the oven is because that igniter is weak and not drawing the proper power to allow the gas valve to open. By replacing the oven igniter it will open the gas valve and once again heat the oven.
GENE
Oct 16, 2011 | Premier P36S318BP Gas Kitchen Range
MY OVEN DOES NOT COME ON. WHEN I USE TO TURN IT ON YOU CAN HEAR IT COME. I'VE HAD IT NOW FOR ABOUT 8 YEARS
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 04, 2011 | Sears 61301 Gas Kitchen Range
The top burners all work fine. When I turn on the oven, there is no smell of gas, or anything. Any suggestions? the stove top burners are working well but the oven is not generating any heat although the...
IF THIS IS A NEW STOVE THERE IS A VALVE IF YOU PULL OUT THE LOWER DRAWER AND LOOK WITH A FLASH LIGHT YOU WILL SEE A VALVE AT THE REAR OF THE STOVEAT THE LOWER LEFT OF THE VALVE THERE IS A TINY LITTLE HANDLE WHICH OPENS THE GAS TO THE OVEN FLIP THE LITTLE LEVER SO IT IS IN THE OPEN POSSITION, THERE ARE NO MARKS SAYING OPEN OR CLOSED AND THE LEVER IS VERY HARD TO SEE
TRY THIS AND SEE IF THE OVEN STARTS WORKING
Aug 25, 2009 | Tappan TGF303BW Gas Range
My professional series oven preheats and then stops heating.
HI, there may be some issues within the dual safety gas valves. they mat be malfunctioning. these valves control the gas flow and if the shut prematurely, it will disrupt the heating process. You could also have a sensor issue as well but, im sensing that this abnormal shutdown is being cuased by a fualty Dual oven safety valve assembly.
Please rate and god bless:)
Apr 15, 2009 | Frigidaire GLGF386DC Stainless Steel Gas...
Vulcan Range that wasn't heating.
The half inch tubing should be adequate under most circumstances. However, you may run into volume issues while using the oven and a few burners at the same time. If it bothers you, replace it. The door should be flush (or close to it) on the sides and the top. If you have an air gap, check the hinges.
Nov 10, 2008 | Vulcan 36L Gas Kitchen Range
OVEN WILL NOT HEAT
replace the oven ignitor, its glowing, but not strong enough to open your valve, very common issue
Oct 25, 2008 | Tappan TGF320 Gas Kitchen Range
Oven problem.
Only 81/2!! most are only expected to give you 5 good yrs anything else is extras. Your problem may be a defective gas valve (safety valve). Also it may be a defective ignitor - the more likely to go bad (if replacing stuff replace ignitor before safety valve. is there a glowing in the oven? does the flames come on any at all?
Post a response
Regards
Sep 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Microwave Spacemaker over the range
It sounds like you may have either a defective keypad or control board.
Is the cottage kept heated in cold months?
Is there any rust on the microwave chassis underneath or on other appliances or surfaces inside the cottage?
This would be evidence that there is condensation settling on the controls or keypad of the oven.
We can normally repair a control panel assembly for $39.95 and if it needs a new keypad, that can add anywhere from $50-$100 to the total, depending on the part cost.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Elite 36 restaurant range
let me see if I am understanding you. The oven used to heat up and then shut down after 10 minutes. then you had a guy replace the valve and thermostat on the same oven, and now it will not shut off at all? I think maybe your repair guy connected something wrong. if you have 2 of these same ovens, visually check the one that works against the one that don't, see if there are any differences.
Nov 15, 2007 | Imperial IR-6-C Elite Gas Kitchen Range
Kitchen Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
