Question about HP Garden
4.5 hp Tecumseh sprays gas from carb while running poorly. Compression feels low.
    New Friend:
  • 47 Answers
I presume you are referring to fuel spraying out through the top of the carburetor (ventury) where the air cleaner would normally bolt onto?
This issue can be caused by several things...
1) Burnt or worn intake valve(s), allowing fuel to be forced back through the carb under the compression stroke. (Compression should be around 40 + lbs)
2) The screw which holds the air cleaner onto the carb is not threaded into the carb. (This interrupts the delicate airflow mixture into the engine)
3) The choke butterfly is not operating properly.
Posted on May 02, 2017
    Top Expert:
  • HP Master
  • 49,191 Answers
Indicates a worn cylinder and ring failure
as small engines suffer from a dusting problem from inefficient air filters and lack of service problems they tend to wear out well before a reasonable period of time
Most are not economical to repair as new motors are close to rebuild costs
Vf4h wisconsin has fire and compression , does not hit on one side
check the compression if its low mite miss at slow rpm is the valve set to tight can you feel a little space between the valve stem end and rocker or tapet if not adjust or file down to get .006 thousths
next if carbon crumb is squashed onto the valve seat you may have to put some carb spray into the port exhaust take muffler off spray inside to we tvalve then crank cylinder several time try this is the fuel pump working enough put gas in tank then prim the carb with a spoonful of gas try start the motor repeat if nessesary running now? no spray oil on the governer springs and linkages reve motor while its running by moving governor linkage dose this restore to normal it did my motor its weird
Dec 25, 2017 | Cars & Trucks
4.5 hp 4 cycle Tecumseh new carb, sprays gas out carb and floods plug. Very little feel compredsoon
check float in carb probably stuck or sticking causing needle valve to stay open
May 02, 2017 | HP Garden
I installed new carb. on my tecumseh 5hp. snow king and it wont start. I have spark and gas is flowing out of carb.
This can be very frustrating and tough on the back and arm.
Always confirm the the fuel tank valve is open and the stop/run switch is in run position
It takes three things to run:
  1. Compression. This is the resistance that you feel as you crank the engine. Some engines have compression release to assist getting the rotation started. You should be able to feel the compression stroke as you rotate, Remove the plug and you can easily tell the deference. If it had, last time used, been running and starting with no problem I would assume that the compression is OK. Gauges are available to check. at lease 120 PSI
  2. Spark. It is near impossible to lose the spark timing on these. It can only be magnitude and presence. If in doubt about the condition of spark plug replace. I usually lay the plug on top of the head with wire attached and observe for the spark. No spark no start.
  3. Confirm that the throttle is in the wide open position. It is possible during the repair the spring or rod has closed the throttle air valve. Air/fuel mixture is always hard to trouble shoot. I use open choke and starter fluid to conform that compression and spark are working. After that I will choke on a cold motor and pull listening for the first fire. At the first fire I would usually half choke and pull to first run. Full choke for many pulls will only flood engine!! If no joy then I would allow engine to vent and go back to start fluid. If it will run on start fluid than either carburetor is messed up or quality of fuel is bad.
If after several tries and fuel is certain to be good remove plug and check for gas. It is possible that the new carb float valve or mixture adjustment screws are messed up.
Jan 10, 2016 | Tecumseh Garden
20 hp tecumseh fuel problems
check for power to the solenoid on the bottom of the carb if it has power take it off they stick closed as well
May 28, 2012 | Murray Garden
Carburators are not getting fuel
have a murray 20 hp tecumseh has gas in the bowl but wont start unless u spray the carb then it dies when u stop spraying any ideas
Apr 14, 2011 | Tecumseh Enduro VTwin Vertical Engine with...
1980 yamaha mx 80 g idles fine but give it gas an it dies
One of 2 things. Either a dirty carb(most likely) or low compression.
If you don't have access to a compression gauge, just feel the kicker by hand. It should take some strength to push it down with a pronounced resistance as the engine builds compression. Too little compresion and the engine cannot ignite all the fuel the carb is trying to feed it. Basically blowing out the fire.
Remove carb and totally disassemble it. Clean all parts and make sure every orifice is clear by spraying carb cleaner through it. Any place you spray should result in the spray coming out somewhere. If not you have a clog. Given your description, i would pay special attention to the main nozzle.(brass tube with holes down the side)
Jun 11, 2010 | 1986 Yamaha RD 350
Engine will not run/tecumseh enginelstall once it starts/hsk model
I assume this is on a snowblower?
Be sure you have fresh fuel.
You can also remove the bowl on the carb and spray carb cleaner in any orfice you see.
Always store a snowblower with fuel stabilizer in it. Otherwise it the fuel can "varnish" the inside of the carb and cause problem.
If it still doesn't start check compression.
Jan 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
CANT GET SNOWTHROWER TO RUN IT WILL RUN IF I SPRAY STARTER FLUID IN CARBARATOR BUT WONT RUN BY IT SELF
sounds like needle valve that is attatched to float bowl is stuck, may want to drop float bowl and let some gas run out. or at least take out main jet that holds float bowl on and let some fuel run out. Old fuel will varnish and make carb. parts stick and or clog jets. Careful as you know gas is very flammable , do it outside. If it doesn't start after that i would have carb rebuilt. hope this helps
Jan 01, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh 17.5 hp ohv engine won't start
check valve clearance. if ok you going have change carb.sometimes i rebuild a carb everthing seam ok but carb wont work right so i have get a new carb and it works fine evertime
Jul 20, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
Top HP Garden Experts
solver2010
andrewdwhite
ray gallant
Are you a HP Garden Expert? Answer questions, earn points and help others
