Question about HP Garden
4.5 hp 4 cycle Tecumseh new carb, sprays gas out carb and floods plug. Very little feel compredsoon
    New Friend:
  • 47 Answers
Compression should be a minimum of 40 psi.
Posted on May 02, 2017
    Top Expert:
  • HP Master
  • 14,512 Answers
Check float in carb probably stuck or sticking causing needle valve to stay open
Testimonial: "Float and needle ok. Why does it spray gas out of carburator while running poorly."
  • Mike decker May 02, 2017
    Float and needle ok. Why does it spray gas out of the carburator while running poorly? Also, feels like very little compression.
    It all began when it wouldn't run unless you kept pressing the primer bulb. Put on rebuilt carburator and now it it starts but runs poorly while spraying gas vapor out of carburator. Also find with a swooshing kind of sound.
4.5 hp Tecumseh sprays gas from carb while running poorly. Compression feels low.
indicates a worn cylinder and ring failure
as small engines suffer from a dusting problem from inefficient air filters and lack of service problems they tend to wear out well before a reasonable period of time
Most are not economical to repair as new motors are close to rebuild costs
May 02, 2017 | HP Garden
Just installed a new carburetor on a Tecumseh Snow King 8 hp engine. Gas is getting to the carburetor but no gas is filling the bowl and engine won't start
Sounds like the carb needle valve is stuck closed. Try loosening the bolts holding the carb to the engine, then tapping the carb lightly with a hammer. If gas then flows to the carb, re-tighten the carb bolts evenly and not too tightly.
Dec 27, 2014 | Tecumseh Garden
I have a tecumseh murray tiller 2 hp 10"
sounds like it needs a good carb cleaning
Mar 25, 2012 | Garden
Carburators are not getting fuel
have a murray 20 hp tecumseh has gas in the bowl but wont start unless u spray the carb then it dies when u stop spraying any ideas
Apr 14, 2011 | Tecumseh Enduro VTwin Vertical Engine with...
Will not start
If you have a spark plug wrench take out the spark plug look at it if it is all wet engine is flooded with gas,dry it and clean it if it is dry its not getting gas, try putting in a new spark plug. is there gas in tank , is switch on, is gas turned off, is the tank full, is the gas old and stinky? has the tiller sat for months carb may be plugged check ,engine oil level, try a little shot of engine starting fluid or gas sprayed into carb needle valve in carb may be pluged, float in carb may be stuck. tap on carburetor good luck
Jan 31, 2011 | Troy-Bilt Garden
I have an old (10-15 yrs) Craftsman Snowblower, equipped with a Tecumseh Snow King 4 cycle, 5 hp engine that hasn't run in over three years due to having been stored. I emptied the tank and put in fresh...
You are on the right track. Do check the air cleaner, and also check your oil level and condition. If the oil's been in there for 3 years, I'd change it.
Also pull the carb off the motor, and get a spray can of carb spray cleaner and clean the bowl, needle valve, around the float, and in any ports, jets, etc.
Drain a bit of the gas out and check to make sure you've got gas flowing, that it's clean and not blocked.Look in the carb bowl...make sure it's not full of sediment, water etc... Spray all the carb linkage and make sure it's all working freely.
While you're at it, use the spray cleaner to spray off the tip of the spark plug, and use some fine sandpaper to clean up the electrode. Then pull the motor thru with the spark plug out , but still attached to the spark plug wire and check for spark. If no spark, replace with a new one. If it's an older style ignition, it may even have contact points that youll need to clean and regap..
Dec 16, 2009 | Sport & Outdoor - Others
Tecumseh HM80 on coleman generator. won"t stabilize, backfires. new plug, fresh gas 'carb cleaned. starts first time'new air filter. any suggestions?
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Mar 01, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Jan 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
26 people viewed this question
Top HP Garden Experts
Vernon Taylor
michael vanier
Are you a HP Garden Expert? Answer questions, earn points and help others
