Question about Measuring Tools & Sensors
My WS9620 does no show me the outside readings.batteries are new & the outside unit shows the temp. &the humidity
    New Friend:
    Problem Solver:
  • 18 Answers
Remove all batteries, bring the two units together and put the batteries in the base unit first, then the outdoor unit; they should sync within 2-3 minutes. Once they have exchanged temp and humidity once, you can separate them. Good luck.
Posted on May 02, 2017
The outside temp won't show up on my new weather station
  • Remove all batteries
  • Install batteries in outside unit and wait for it to begin sending temperature signal to inside unit.
  • Install batteries in inside unit. You should see outside temperature displayed.
  • If this doesn't work, the outside unit may be defective.
Apr 04, 2018 | Measuring Tools & Sensors
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 | Home
Outside temp battery quit yesterday. replaced batteries inside and out. outside temp will not show. what to do?
  • Remove batteries from both units
  • Install batteries in outside unit. Allow time for it to initialize and begin transmitting data.
  • Install batteries in inside unit. You should see outside temperature displayed. If not, there may be a problem with the outside unit.
Mar 18, 2018 | Measuring Tools & Sensors
Barolo AU9 weather station. I replaced batteries in the outside temp unit. how do I activate it to show outside temp on the main inside unit
  • Install batteries in outside transmitter and wait for it to initialize and begin sending data
  • Install batteries in inside receiver and observe temperature reading
Sep 22, 2017 | Measuring Tools & Sensors
Why my station do not show interior temp and humidity
Make sure that the battery is good and that you have reset it after installation. If that does not do the trick then the electronics of your unit are no good. A weak battery will result in incorrect or no readings at all.
Jun 02, 2016 | Measuring Tools & Sensors
I have model 9630 The Weather Channel. I was not receiving the outside temp so I replaced the batteries in both units. After several trys it's still not working. The receiver shows OF.L for the inside
  • Install batteries in outside unit and allow time for it to begin transmitting date
  • Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit may be defective.
Oct 31, 2017 | Measuring Tools & Sensors
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Apr 24, 2009 | Lands Phones
Measuring Tools & Sensors Logo
644 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
