I HAVE PANOSONIC TV CRT TRYING TO CONNECT RECEIVER ONLY AUDIO IS WORKING BUT NO VIDEO.
  • james
    james May 03, 2017
    normal receiver with audio video cable port
  • Audio Player... Master
  • 2,045 Answers
What kind of receiver and what are cable options in both?
Posted on May 02, 2017
  • 47 Answers
SOURCE: WII Video doesn't show up with my receiver
Make sure that you have the reciever in the correct setting.  Sometimes on them the s-vid is like video 3 or so on
Posted on Oct 27, 2007
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Posted on Feb 02, 2008
  • 6 Answers
SOURCE: can't get audio from HD TV to run through Yamaha receiver speaker
be more specific!...how is the tv hooked up? hdmi, component, straight to the tv, or into the amp then tv?....what audio out? optical, digital? also what are you trying to view? local programming? cable/sat? dvd? your best bet is to ignore video on the amp and go straight to tv. can't help u more until i have more specifics.
Posted on Jan 23, 2009
  • 290 Answers
SOURCE: HDMI only for video and sound through regular audio input
DVI does NOT support sound unlike HDMI. Hopefully your PC has a Co-axial S/PDIF digital output. If not you might want to spend the $50 and buy a nice one from Creative. Modern motherboards are even coming with HDMI built-in but that's NOT your situation. I use a 15" DVI to HDMI cable but you are probably using an adapter and the a regular HDMI cable. Get co-axial digital audio cable of the right length and connect it to the co-axial inputs (they're in the upper corner). Use the remote's set-up button and select the "Digital Input" option. This is very powerful. You can assign any of the Optical or Co-axial inputs to any associated device.
I have my PC as Video 3 with sound coming in via HDMI which I assign under the "HDMI Video" menu and sound under the "Digital Input" as "Coax1". I use "Coax2" for the DVD player that lacks an optical output. If you use regular analog you are screwed as you found out. I usually use the headphone jack and an extension cable with the Computer and watch on it's monitor.
All HDTV sets are **** compared to a decent computer monitor. The deliver MUCH clearer video and much higher resolutions that shitty the 1080 HDTV maxes out at. ATSC is **** compared to a PC. Grated, cable is junk compared to ATSC at 1080i but that's another story. Yet, comparing ATSC to a computer is like comparing NTSC or digital cables' crappy 480i with ATSC at 1080i. It that much greater. At least 720p is wide screened unlike 480i garbage that's most of Comcast's "HD" digital junk.
Posted on Mar 01, 2009
  • 142 Answers
SOURCE: I have a macbook and want to hook up to my dynex
Your mac would have to have a fully hd compliant mini port. To be honest I havent even checked to see if any do. Then you would want to get a mini video port to HDMI adapter. If you don't have one of the newer Intel mac then chances are you cant do sound through that port, which is what your tv is looking for on the hdmi port.
Easiest solution is to hook your headphone port on your laptop to a stereo or some decent computer speakers, which usually sound better than tv speakers anyway.
Posted on Jan 11, 2010
HOW DO YOU CONNECT CABLE BOX
Connect a Cable Box to a Receiver:
1 Gather all your tools, parts and cables together before you start the connection process. Chances are you will need to connect several items at the same time, including your TV, audio system and TV cable receiver. Your cable box manual is likely to include a diagram of how to make the appropriate connections, so it's important that you read it before attempting any links.
2 Connect the output of the cable box to the input of the receiver. If you are connecting an audio system as well, make sure the audio output cables go directly into the receiver and, from there, to the cable box. Avoid direct connections; instead, go through the receiver for all secondary connections.
3 Select the correct jacks for sound and video. A newer model of receiver should offer several options, including analog TV out and DTV out. It should also offer an S-video and a service port. Depending on the type of cable box you use, one or more of the same jacks will be available there, too. When connecting both systems, make sure cables go between similar outputs.
4 Use an S-video connection cable to link your TV with your cable box. S-video connection cables allow you to preserve good quality in both image and audio. Most cable boxes come with S-video connection cables, but you can get them at any electronics store. Once you have them, simply connect both ends to the right output. It'll be easy to identify, because it's usually the only round one available.
5 Plug the TV, cable box and receiver into an electrical outlet to make sure everything is working properly. If you are getting static or interference, you may need to tighten the connections or change the cables.
Sep 03, 2011 | Sony KV-35V65 TV
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
I am trying to hook my tv up....what settings do I need to watch direct tv???
If you have a Sanyo TV with out audio/video connections, you will be using an RF connection cord between your TV and the satellite receiver. You will operate your TV on channel 3 or 4, match this with the channel 3 or 4 on the receiver box.If your TV has audio/video input connections, you will need to purchase rca connectors. They will have a red connection for right audio, white connection for left audio, and yellow is your video connection. The color codes will be on the input connections on the TV and the satellite receiver as well. You will than program the TV to input one or two, of the TV to receive the signal from the receiver. Use the satellite remote to control channels on the receiver box. When you are through watching TV, be sure to shut off your TV as well. Thanks for asking and show a few hands of support!
Feb 19, 2011 | Sansui Televison & Video
Can I hook up my tv wirelessly to my home network?
Well I have, using those 2.4GHz AV Video/Audio Senders/Receivers, and as long as the PC you wish to watch has Composite Video OUT, then you can connect the "Sender" to the Video & Audio OUT, this in turn is "Transmitted" to the Receiver, that OUTPUTS again composite Video & Audio to the TV's Composite Video IN and AV IN. Yellow Video & Red & White are Audio IN. Works a treat.
Feb 15, 2010 | Toshiba 32A33 32" TV
I am trying to use my Denon AVR-1802 to connect my cable box to my TV. The problem is that I don't have any speakers connected to the 1802, I just want to route the cable box's video and audio to the TV...
connect your analog output from the cablebox to the receiver md/tape in. then connect your tv audio input to the md/tape out of the receiver. or you could just pass it straight from the box to the tv, bypassing the receiver altogether.
Nov 03, 2009 | Denon AVR-1802 Receiver
I have connected my Charter HDTV settop box to the strdh700 in the 'sat in' hdmi connection, then connected the 'out' hdmi to my sony bravia tv and the signal isn't getting there. any suggestions?
If you're not getting the audio signal, please select the Audio for HDMI to TV+AMP in Menu display. If you're not getting the videos, please check if the TV is HD ready and supports 1080p signals. Also check if the connections are firm and secure and you selected the correct input on both Receiver and TV. Please try connect the Settop box to different HDMI port of the receiver and try. You can also try connecting the Set top box to tv directly and check if its working. If its working fine directly with the TV, you may try to replace the cable and try else the receiver may require service
Sep 22, 2009 | Sony STR-DH700 A/V Receiver
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Audio, but No video when connecting DVD player to TV
Try checking the AV cable. Just interchange the Audio and Video cables, and if now you get video, and no audio, problem is faulty cables. Replace.
Apr 15, 2007 | Toshiba CZ27T31 27" TV
 Grubhead
Grubhead
