Question about Refrigerators
The refrigerator and freezer are not working.
The fridge and freezer are not working. I can change the temperature but the compressor is not working Model: Miele, KFN 14823 SD frost free fridge freezer with dynamic cooling
  • 231 Answers
Most cases the unit is dirty on the coils underneath. Pull the grate off and carefully vacuum it all out.
If it will not turn on, look at the other items in this thread
Posted on May 02, 2017
Testimonial: "Did not help. It seems that the compressor does not work. Any solution?"
  • Bosse Photos May 03, 2017
    There are many conditions that may prevent the compressor from coming on. It may have electrically failed internally, or mechanically failed internally, the starting capacitor may be shot, the thermostat may have failed, a lockout may be bad or tripped, or you may have bad wiring. You would need to know how to trace the electrical diagram, usually located on the back, and test each point of power to the compressor. For a non technician, this may be fatal if not performed safely. If the compressor is hot, humming, it may be trying to start, but the capacitor is failed or it is mechanically seized. Not a recommended fix for a DIY.
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
Is the compressor running? Getting power? thermostat any good? How about the start cap/relay?
Testimonial: "The power is OK. I can set the temperature of the fridge and freezer. The compressor seems silent (not working)"
  • Hossein Shokri
    Hossein Shokri May 02, 2017
    Fridge model is
    "Miele, KFN 14823 SD, frost free fridge freezer with dynamic cooling."
  • richie46 May 03, 2017
    If compressor receiving power and nada, change the start relay or capacitor. If still mada your compressor has gone to heaven.
    New Friend:
  • 47 Answers
Additional information regarding the make, model and serial number would be helpful in diagnosing many problematic issues.
Testimonial: "Miele, KFN 14823 SD, frost free fridge freezer with dynamic cooling."
Why is the refrigerator side is freezing food
First some fridge 101, the refrigerator/freezer models cool by directly refrigerating the freezer section and the refrigerator section is cooled when "some" of the cold air from the freezer is directed over to the refrigerator side (typically by a fan) to keep food fresh and not frozen a temperature controlling damper opens and closes to regulate the temperature of the fridge by introducing more or below freezing air into the cabinet. In older models where the freezer was on top the air simply "gravity" drained into the refrigerator cabinet, if the food was too cold you turned the fridge knob up and less air sank from the freezer to the fridge, simple but effective.
When you adjust the temperature level it controls the freezer temperature and this turns the compressor on and off to keep the food frozen. There is typically a knob or lever and some even have electric dampers that open and close to direct more or less air from the freezer and direct it to the refrigerator cabinet based on your temperature requirements.
Now that you know how it works there are a couple things to check. If the condenser coil is plugged with dust the internal system pressure will rise and in some cases make the fridge an over achiever and can chill too much so check/clean the condenser coil. Check the freezer temperature control and turn in up, also make sure the fridge temperature control setting is not set too cold.
Finally as the temperature changes around the refrigerator it will have an effect on the inside of the fridge too so expect to turn it up and down as the environment changes, down in the summer and up in the winter.
Hope the novel helps to resolve your issues.
Nov 01, 2017 | Refrigerators
Freezer goes -9 and fridge goes to 40 I have set it to 0 for freezer and 34 for fridge it changes on its own
Depends on type of refrigerator freezer you have, but you need to realize that the evaporator (cooling coils) are in the freezer, and the cold air produced in the freezer is then circulated via an evaporator fan into the refrigerator section. The thermostat the cycles the compressor motor is located in the refrigerator, and the compressor will run until the temperature reaches the desired level in the refrigerator. On most units, the freezer temperature setting simply regulates how much cold air is circulated into the refrigerator.
What you are describing is that the freezer is working fine (almost too good), but the air is not properly getting to the refrigerator area. Several things can be causing restricted airflow, including a faulty evaporator fan, icing of the evaporator coils because of a malfunction in the automatic defrost system. Check to see if there is frost or ice build up in the back or bottom of the freezer. The proper temperatures should be around 0 F for the freezer and 38-40 degrees F for the refrigerator.
Feb 25, 2015 | Refrigerators
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
The fridge / freezer is still operating but not to its full capacity. The freezer is working at a temp of the fridge, and the fridge is just cool. I have adjusted the temperature setting and nothing has...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Sep 01, 2011 | Refrigerators
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
Side by side, freezer working fine but fridge side not cold enought, set at coldest temp. Could vent between freezer and fridge be blocked?
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MSD2656G Side by Side Refrigerator
I have a rm2611 refrigerator which has lights, no fan
There's a capacitor by or on the compressor that probalbly needs replacing. This is the cheapest route .
Jul 05, 2009 | Dometic RM2620 Refrigerator
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
