Question about Dishwashers
Lamona dishwasherpumps out but at the end of the cycle the pump does not stop
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
Check for water in the Base , a hose often comes off on these , if not , programmer is faulty
Posted on May 03, 2017
My Lamona dishwasher HJA 8650 lower spray arm wont rotate, water is spyaying out and nothing in place to stop it rotating, can you help?
Sounds like the pump that pushes the water up to the spray arm is going south on you.
Check to see if the pump or any of the piping, or sprayer arm jets are clogged.
Feb 23, 2017 | Dishwashers
Machine will not finish any wash cycle, It stops, illuminates END light and beeps? Is there a reset or is this at the end of it's life?
Hi, quite often cycles are not finished because the drain pump has an intermittent fault. It may pump ok at the start of the cycle but towards the end it's had enough and stops. Leaving water in the bottom of the drum. If this is similar to your machine's symptom then I would be checking the pump. They are cheap to buy and easy to fit.
Hope this helps you.
Oct 04, 2015 | Washing Machines
My washing machine washed a load on the medium cycle but when it is time for it to drain the water it just stop the only thing it is doing is fulling back up with water and not doing anything else on
Not sure what you are saying, I assume the water is not pumping out at the end of the wash cycle. Is the water draining out at the end of each cycle? Is it spinning at all? Is the exhaust tubing clogged? Is the pump burned out or are you trying to pump it uphill too much. If it's stopping mid wash, try advancing it manually past where it's stuck and see if it continues. I have that problem, the tank fills with water and it gets stuck at the 6 minute changeover. It will run stuck at this point indefinitely if I let it. We just set a timer for the fill time, then manually advance it past this stopping point.
Sep 30, 2014 | Washing Machines
Lamona hja8630
could be a water inlet valve. Turn off water supply....disconnect hose at dishwasher....turn water supply on slightly to ensure water supply and hose are ok. If you have water there , problem could be water inlett valve or perhaps a sticky float valve.
Oct 01, 2013 | Dishwashers
Steam coming out of dishwasher
Sounds like the drain hose is partially plugged restricting the water to completely pump out.
Mar 28, 2017 | Dishwashers
My system keeps flashing the 90 code indicating low water flow. My pool is full. What's wrong and how do I get the system to run normal? I just set the pool up and it has flash this cood from the...
Most low flow alarms are caused by the pump stopping before the chlorinator cycle ends. You must set the chlorinator hrs between the pump cycle. Start and set your pump cycle, wait at least15 to 30 minutes and then set you chlorinator hrs and make sure to it completes it's cycle at least 15 to 30 minutes before the pump cycle ends, If your pump turns off before the chlorinator cycle ends, you will get a low flow alarm......
Hope this helps, if it does, please rate...
Jul 25, 2011 | Intex Automatic Salt Water System for ...
Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
Feb 21, 2010 | Dishwashers
The washer squeals as the water is filling the tub and continues through most of the cycles. As the machine agitates quickly, the squealing stops. However, it squeals at the end of the cycle.
Sounds like the pump.  When it first fills the pump recirculates the water, then it comes on at the end of each cycle to drain the water.  The pump is on the bottom of the machine, on the right side.
Dec 19, 2009 | Fisher Paykel EcoSmart GWL15
Dishwashers Logo
Top Dishwashers Experts
