Question about Orion Televison & Video
How do I activate my Orion channel - Orion Televison & Video
I have anew orion tv model no.tv1934a an I was asking if it's a digital tv.because I have a antenna but I can't pick up channels?
This model is not digital.....to receive digital channels you need a digital set top box or another type of digital receiver to get any channels!
Feb 01, 2015 | Orion Televison & Video
How to change orion tv model stv2555a to a/v with no remote
Try to switch channels all the down and right below channel 2 or above 125,(that is in between the two channels) you should get video in there. good luck
Nov 03, 2009 | Orion STV2763 27" TV
Orion tv 1333
Try to use the add a channel tool or, search for digital channel tool. this should pull up most of your available channels in your area. if you've done this then, you may have only one active dtv channel available at this time.
Feb 04, 2009 | Orion1934 19" TV
Taping from surveillence cameras
the vcr has to be set to moniter the camera!...buy a cheap universal remote and push monitor in the menu screen!
Dec 10, 2008 | Orion VR213 VHS VCR
Orion 2501
use your remote and fine tune the channel 15
Oct 02, 2008 | Orion1934 19" TV
Orion tv only has 2 channels and it's hooked up to cable
go to menu,go to were it says cable and air,select cable. then go up to auto program do search, this should do what you want.
Jun 13, 2008 | Orion Televison & Video
I need the parental control code for a 19 inch Orion color tv
go to a channel that will let you turn tv sound down to zero. then turn tv to channel block asking for password. next on the tv hold the volume down button and at the same time hold down the number 0 on the remote. It should unlock
Feb 16, 2008 | Orion1934 19" TV
Tuning in my orion tv
Do you just mean to select channels, or do you need to have it search for active channels (programming mode)? If just select channels, then most remotes have channel up & down buttons, in addition to the number pad. To select by numbers, use 2 digits: 04, 06, 08, 10, 22 and so forth.
If the set needs to be placed in the setup or autoprogram mode to search for active channels, then the menu functions must be used.
You may be able to find an online manual on Orion's website. Use your TV model number.
Jan 08, 2008 | Orion STV2763 27" TV
Wrong or 3-Digit Channel Numbers
that request is not available...firm-wared chip proprietary from orion
Jun 01, 2007 | Orion STV2763 27" TV
Televison & Video Logo
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
