Question about The Computers & Internet
How do I enter my frys receipt for the 50 fuel points
Trying to check my Kroger fuel points but get too many pop ups and no information. Web site is useless.
There is often a small link at the bottom of the screen saying 'Send Feedback'. and here you go, there is. I get no pop ups :>)
I found this about Fuel Points.
How do I keep track of my fuel points?
Your current fuel points balance is located at the bottom of your Kroger receipt. You may also
Customer Service
Dec 04, 2016 | Cars & Trucks
What are my kroger fuel points
Mary, Got this Info from Link below. Your current fuel points balance is located at the bottom of your Kroger receipt. You may also check your points balance on our website or on the Kroger mobile app for your iPhone or Android device by registering your Kroger Plus Card number. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kroger
How To Save 1 Off Every Gallon Of Gas 4x Kroger Fuel Points Extended...
Kroger 4X Fuel Rewards Gift Card Promotion Valid through March 27th
Apr 26, 2016 | Miscellaneous
What is my krogerfuel points balance?
it tells you on every receipt from the store . we can not access that for you .
Oct 23, 2015 | Cars & Trucks
2003 Cavalier fuse shorts and frys the fuel pump.
do you ever change the fuel filter to reduce the strain on the pump?do you always run the tank low the fuel helps cool the pump
Jul 09, 2012 | 2003 Chevrolet Cavalier
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
Oct 27, 2009 | Sharp XE-A404 PC Desktop
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
function is in the “ON” status."
Sep 24, 2009 | Sharp XE-A404 PC Desktop
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
OFF.
All the best!
Greg
Aug 01, 2009 | Sharp XE-A404 PC Desktop
Adobe photoshop elements 2.0 Plus photoshop album 2.0 serial numbers
Hi there!
As i understand you has lost your serial number and are trying to install Adobe on a new PC.
Have you ever registered your product online? Do you still have the original receipt? If so, call Adobe Customer Support and they would help you.
Next you could call your distributor from whom you bought the package(frys) and ask him for the receipt number or the serial number if he has the copy.
This statement is taken from Adobe site
"If you cannot find your serial number and it is not in our registration database, Adobe can reissue your serial number in certain cases. This applies only to current shipping versions of Adobe branded or Macromedia branded products, and one version prior to the current version. Please contact Adobe Customer Service with a copy of your Proof of Purchase "
Click on the link to find the above Statement,
http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_15292&sliceId=2
Click on the below link to find Customer Service in your country and region,
http://www.adobe.com/support/contact/
Regards,
Olafsson.
Aug 18, 2008 | Adobe Photoshop Elements 2.0 for PC
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
tim brauer
tim brauer
Dilum Senarath
Dilum Senarath
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
