Mitsubishi WS-48311 48" Rear Projection Television Logo
Posted on Jul 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant see picture
The screen comes on fine but there is this big black box that will not go off to let me see the picture
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Jul 25, 2009
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564574
Points
12312
This is usually a closed caption box. Try working through the menus looking for closed captioning options and turn them off. If that fails to resolve the problem, please confirm your model number and I'll check further.
Thanks,
Dan
2helpful
Picture has a black image (box that black out part of the screen) that comes on seconds after TV is turned on, leaves when volume is adjusted, then returns after a few seconds. Does not appear when Wii is...
You need to go into your menu and go to close caption and turn off the text screen that some how got turn on, that big black box is call a text screen, and you are not the first person that this has happen too, Take care.
There's a big black box obscuring the screen
Check the menu settings - closed captioning(CC) is propably on -switch CC to Off.
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
10helpful
Zenith TV has a big black box in the middle of the screen.
After reading other postings, we figured out that it was the caption box, went to menu and turned it off.
Thanks for the great site, we wouldn't have figured it out without it !
Jen
8helpful
2answers
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
2helpful
2answers
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
1helpful
Camera will take picture, but the picture is coming out black!!!! Help Please!!!
Dear vera11:
The symptoms you're describing sound like a classic case of having a faiiled CCD image sensor.
First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have a CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
4 Scrolling black boxes with the picture showing in the background
PIP DISPLAYED IN ALL FOUR CORNERS OF PIX. UNPLUG UNIT MOMENTARILY TO RESET. or the pip modual has failed.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
