Continental/girbau dryer CG78/85 error code of E-OP
Hi this the erro that appears on my Girbau dryer: Buner Control fault. can someone help me?
The gas heating element is failing to ignite. The igniter or gas valve could be at fault.
Oct 30, 2017 | Dryers
Girbau ms 623 lc-E
my Englesh is bad, when i start the laudry machine GIRBAU MS623, the display show ALARM U00, i need help
Jan 15, 2014 | Cars & Trucks
What does the error code "OP" mean?
OP - Open Thermistor - Replace thermistor.
Aug 27, 2013 | Washing Machines
How can I find a supplier of a replacement door gasket for a Girbau 20lb commercial washer?
I would suggest staying on the web and doing a product search and you should be presented with suitable suppliers. Just type into your web browser 'girbau washer' and see what turns up. That's what I would do.
Sorry I can't be more helpful.
John C
Feb 16, 2011 | Washing Machines
OP error code. What is wrong with my Hayward pool
OP is the error code for a faulty Temperature Sensor. Try replacing the Temperature Sensor. I have seen many of these units have the wires chewed up by mice, etc., so you may want to check the wiring for any damage.
Jul 03, 2010 | Hayward 116k BTU HeatPro Digital Heat Pump...
Dryer will not spin
Maybe I can help with the Washer if it's a FA6800A/FAV9800A. Is it one of those and why do you feel you need a lid switch? Are you getting OP,OD,FL error codes to the LED display if the machine model is a FAV6800A.....Rich
Jun 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have an error code OP what should i do
You could have a lid magnet out of position. Quick check for that is to place a magnet over the left bumper with the lid raised and see if the OP error code clears.
If it does you need to remove the inner panel of the lid to access the lid magnet see page 32 of the Service Manual for the procedure.
If the external magnet doesn’t clear the OP error code you will have to start troubleshooting the Left Hand Lid Lock. You could have severe corrosion with and an open lead on the magnetic reed switch in the Left Hand Lid lock. Link to replacement Left Hand Lid Lock
See this post Left Hand Lid Lock Troubleshooting for further info. I discuss troubleshooting the OD error code but you troubleshoot the OP error code the same way……Rich
Jun 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The washer is stuck locked. When turned on it shows OP where the minutes are!! PLEASE HELP !!
Don’t force the lid open and break the lid locks.
Here is the Service Manual and parts look up;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Use this procedure for releasing the washer top from the base;
Un plug the 120VAC power cord to the washer.
To raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
This will get the clothes out.
With the washer top raised gently push to Left and Right lid lock latches to outside of the lid the unlock position.
You can now lower the washer top to the base.
Do you want to DIY the OP error code?
The OP error code could be caused by a Lid Magnet out of position. To do a quick check with the lid open power up the washer. Do you have the OP error code showing? If so take a large magnet and place it over the grey left lid bumper and see if the OP error code will clear the LED display. A Pic for reference;
If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
e830e40.jpg If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
