Question about The Computers & Internet
Have 1 monitor 2 computers. KVM switch kept switching back and forth so took computers loose. Now the monitor is like it's stuck switching and won't show pc it's connected to
    Top Expert:
  • The Master
  • 12,962 Answers
Do a hard reset on monitor and then connect it directly to a computer and see what happens. Your monitor may be having an un reversible seizure!!!!!!!!!!!!!!!!!!
Posted on May 02, 2017
Testimonial: "How do I do that? It's an hpS2031a"
  • richie46 May 02, 2017
    Disconnect the power source from the monitor while it is turned on. Then hold and press the "on" button for a few minutes. Then replug the unit in and turn on. If still the same then you have a real sick puppy on your hands.
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
Remember to check the cables!
For me this device kept doing the switching back and forth thingie until I noticed that one of the display cables was bit out of it's place.
Tightened the screws and Voilá!
All these things with lotsa wires on them... Always remember to check the cables!
on Nov 19, 2007 | Belkin F1DK102U 2-port KVM Switch
Screen resolution keeps switching
If its a usb kvm, check usb connections, one computer should stay fixed, the one that doesn't is your problem
Nov 21, 2011 | Belkin F1DF102PEA 2-port KVM Switch
Kvm switch screen resolution
Formore details please visit
Nov 21, 2011 | Belkin F1DK102P 2-port KVM Switch
I use a Logitech optical cordless mouse w/ 2 computers w/1 monitor. I switch back and forth between computers with a KVM switch. In order to avoid software clashes, I have to switch the mouse's stick (?)...
Im not sure if you can do this. But, I may have an answer for you. Why not buy an Identical mouse and stick. And set up just one mouse with both sticks... Dont know if it will work, but, its worth a try..
Let me know if it does work..Thanks.
hope this helps
Jan 17, 2011 | Logitech Cordless Mouse
Switch starts switching back and forth between computers itself
There are no firmware updates for the GCS62 also the KVM appears to not have a firmware upgrade port. If the KVM is auto-switching have you tried hitting the ESC key or Space Bar? That should stop the auto switching.
Feb 12, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Wobbly screen on mac laptop
are you using a Mac Mini-DVI to DVI adapter or any adapters? This is a VGA video output type of KVM switch so probably the problem is with the adapters involved to it.
Nov 19, 2008 | IOGear MiniView GCS62 2-port KVM Switch
Using KVM-121 with 2 monitors
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
Sep 07, 2008 | D-Link DKVM-2K 2-port KVM Switch
Switching from PC monitor to an HDTV monitor
Yes, this product will do the job. An easier solution, although probably more expensive, would be to use a video card with dual outputs. Using a video card with dual outputs would allow you to see the computer's video on both screens simultaneously.
Dec 22, 2007 | Cables Unlimited 4-Way Video...
Can's switch without it switching back to first PC
Sadly, it is probably the KVM as this particular model has a string of failures and is only rated 2 out of 5 stars on Amazon due to poor performance. :( What I would do first is plug in Computer 2 directly to the monitor, keyboard and mouse with no KVM. If those work fine, it is probably not a computer issue; if you don't get video here, then it is a seperate issue with that PC. If Computer 2 is working, plug both computers into the KVM but switch the cables (plug Computer 1 into the KVM using Computer 2's cables). If Computer 2 shows up and can't switch to Computer 1, then it is the KVM messing up.
Aug 21, 2007 | Belkin F1DK102U 2-port KVM Switch
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
