Question about Craftsman Garden
My rider craftsman model 917280083 the deck sits too low it drags the ground even at the highest settting
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Craftsman Master
  • 902 Answers
Most craftsman have a bar that goes from the deck to the front of the frame that raises or lowers the deck in your case you will want to tighten it up to make the deck higher.
my rider craftsman model 917280083 the deck sits t - deck adjustment bar-c3q2arftkjqadc5o2wwrk5li-3-0.jpg
Posted on May 02, 2017
How to adjust the deck height
left to right, there is a nut on each side between the deck and floor where your feet sit. front to back is the drag links attached to the front of the deck. adjust left/right first, then front to back. make sure tires are aired up before you do it.
Jul 15, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower deck too low
There are two bolts that raise and lower the deck for adjustment on either side of the mower.
Jul 10, 2014 | Craftsman Lt1500
Can any one help with my little problem--I have just purchased a murray ride on mower 12/30 model 31620x20A. it is in very good condition --but I have not got a manual with it SO my question is where can I...
Dear Jim, First thing that I would look at is: make sure that ALL of the tires have the correct inflation. It would surprise you how much lower to the ground the deck is when the tire pressures are low. Sincerely, Larry Springer
Oct 10, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The mower deck is is dragging the ground even on the highest setting
look under unit for either lifting arm--level--cable --mount pin loose damaged or missing
Sep 06, 2011 | Craftsman Garden
I have a sears craftsman rider..model #917.527643, I cannot lower the mower deck to the ground. Any suggestions on how I may fix this problem?
I could not look up by model number. You have the right number of digits, but the sears craftsman parts site would not recognize it. So I am guessing that you have a knob that the operator can reach under the steering wheel and lower and a little left. If you have one of these knobs, it is a deck lower limiter. It is easy to turn if the deck is fully up. If the deck is lowered to bottom and the deck does not go to bottom and you turn this knob you will feel significant resistance. This resistance is caused by the weight of the deck on the limiter. With the deck fully up, turn this knob to fully lower the limiter and then lower the deck. Should go to ground or just a hair higher.
If any questions, please send reply and I will get back to you.
If you found this really helpful, please rate 4 thumbs up.
Jul 14, 2011 | Garden
Craftsman 20 hp 42" lawn tractor moweer deck hitting back wheel on right side when put all the way up. checked for broken parts but none found, help
The deck is either badly out of level or has been twisted by dragging on something. Most riders have rather thin metal used in the deck and it can be damaged much easier than one might think. Re-level the deck and use a small block as a gauge or eye reference point and you may find the deck is bent.
Jun 14, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Even on the highest setting, it still cuts too low. can i adjust it to cut higher?
When you put it in the highest setting can you see the deck actually moving in an upward direction? If not the linkage might be broken or damaged. When you raise the deck up or down with the lever it should move, a deck setting in the full up position is a pretty high setting you have to have some long grass to be cutting in the full up position and still think its to short. You might be able to reposition the deck, if when you look under the unit you see a bracket that controls the deck height setting that has a number of holes in it(maybe even 2 brackets), there should be a pin(s) in one of the holes this could be set in a low position and therefore you can change position to change height of deck.
Oct 15, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
How to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Oct 11, 2009 | Garden
Garden Logo
27 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
