Question about The Computers & Internet
The cord from the phone to the jack isn't long enough. Can I use the one that I have used on my other phone?
I have a phone cord from my phone to the jack with a computer adapter. Can I still use that cord?
    Top Expert:
  • The Master
  • 12,718 Answers
If the cord is good and the ends match up. why not?
Posted on May 02, 2017
3 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: looks like my laptop jack is wornout or broken
If you are good with a soldering iron or know somebody who is this type of repair can be quite easy to do.
INSIDEMYLAPTOP
They have quite a few guides on this type of problem.
If you are not wanting to do it yourself then suitable laptop repairs shop could do it for you. It is usually not too expensive
Posted on Aug 25, 2009
  • 1632 Answers
SOURCE: magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Posted on Dec 27, 2013
Dell inspiron elec cord isn't firm so power turns off
Maybe it's the DC Jack that the power cord plugs into. If the jack is loose then you will experience the issue you are having.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 18, 2012 | Dell Inspiron 1525 Notebook
The speaker phone on our panasonic KX-T7633 dosn't go loud enough. We are trying to hook up an external speaker, but when we plug it into the headphone jack we just get a buzzing noise. Is there a...
There should be a way to do that. 1st make sure speaker jack is fully inserted. If you still have same problem try normal headphones and see if there still is foreign hum- then if headphones work, check the size of both the jacks to see if there the same- you might just have wrong size jack. If that is not the problem the Impedance(ohm symbol) is probably wrong and the phone doesn't have enough power to drive your speaker.. Use a speaker with same Impedance, you might have to use a speaker with its own power supply to get appropiate volume. You could try your PC external speaker. I hope this has been helpful.
Aug 25, 2011 | Panasonic KX-T7633 Corded Phone
I am trying to use a Plantronics CS70N headset with my Mitel 5215 IP Phone. I have the headset plugged into the headset jack on the back on the phone, but there is no head set button. Is there some...
First remove the headset cord from the headset jack. That is only used for corded headsets. Plug the short cord into the jack where the curly cord had been plugged into. The curly cord is now going to be plugged into the base of the charger where the picture is of a handset -- the curly cord goes there. There is a A/C adapter that is plugged in to base that is now plugged into the wall.
Good luck from Headsets Direct!
Jun 29, 2011 | Mitel 5215 IP Phone
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
Telephone line connection
Two options:
1) Pick up a phone line splitter (Radio Shack or just about any other retailer has them) that has a plug on one side and two jacks on the other. Plug this into the phone jack where the line to your computer is connected. Plug the cord to the computer back into one jack on the splitter and plug the line to the fax machine into the other jack. (If it will physically fit into the space on the back of the computer, you can just plug the splitter into the modem connector, plug the line cord into one jack and the fax cord into the other.)
2) (Useful if the phone jack is behind furniture or just hard to get at.) Get a phone line splitter with all jacks (two on one side, on on the other). Unplug the line cord from the computer and plug it into the single jack on one side of the splitter. Then run a new line cord from one of the two jacks on the other side back to your computer. Plug the cord to the fax machine into the other jack.
Jan 27, 2009 | Dell A940 All-In-One InkJet Printer
Second line not working
The phone will show that "line in use" message when it's not connected correctly.
If your two phone lines come in to one jack, make sure you are using a 4-wire line cord connected to the "line 1 and line 2" jack on the phone. You may be using a 2-wire cord so the second line isn't reaching the phone.
If the two lines are on separate jacks you need to connect line 2 to the separate "line 2" jack.
If you know for a fact that both lines are properly connected to the phone and it still doesn't see the second line, then it's time for a new phone.
Dec 10, 2008 | AT&T E2562 Cordless Phone
Fax
To test your fax setup
1 Press Setup.
2 Press 6, and then press 5.
This displays the Tools menu and then selects Run Fax Test.
The HP all-in-one displays the status of the test on the color graphics display and prints a report.
3 Review the report.
– If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause faxing problems.
– If the test fails, review the report for information on how to fix any problems
found. For more information, you can also see the next section, The fax test
failed.
4 Press OK to return to the Setup Menu.
Make sure you used the phone cord supplied in the box with your HP all-in-one
to connect to the telephone wall jack. One end of this special 2-wire phone
cord should be connected to the port labeled "1-LINE" on the back of your
HP all-in-one and the other end to your telephone wall jack
This special 2-wire cord is different from the more common 4-wire phone cords
you might already have in your home or office. Check the end of the cord and
compare it to the two types of cords shown below.
If you used the 4-wire phone cord, disconnect it, find the supplied 2-wire cord,
and then connect the 2-wire cord to the port labeled "1-LINE" on the back of
your HP all-in-one. For more information on connecting this phone cord and
setting up your HP all-in-one for faxing, see Fax setup.
information see The phone cord that came with my HP all-in-one is not long
enough.
● Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP all-in-one and check for a dial tone. If you do not
hear a dial tone, contact your telephone company and have them check the
line.
● Other equipment, which uses the same phone line as the HP all-in-one, might
be in use. For example, you cannot use your HP all-in-one for faxing if an
extension phone is off hook, or if you are using your PC modem to send an email
or access the Internet.
● The phone line connection might be noisy. Phone lines with poor sound quality
(noise) can cause faxing problems. Check the sound quality of the phone line
by plugging a phone into the telephone wall jack and listening for static or
other noise. If you hear noise, turn Error Correction Mode (ECM) off and try
faxing again. For information, see Use error correction mode. If the problem
persists, contact your telephone company.
● If you are using a digital subscriber line (DSL) service, make sure that you
have a DSL filter connected or you will not be able to fax successfully. The
DSL filter removes the digital signal and allows your HP all-in-one to
communicate properly with the phone line. Obtain a DSL filter from your DSL
provider. If you already have a DSL filter, make sure it is connected correctly.
Make sure your HP all-in-one is not connected to a telephone wall jack that is
set up for digital phones. To check if your phone line is digital, connect a
regular analog phone to the line and listen for a dial tone. If you do not hear a
normal sounding dial tone, it might be a phone line set up for digital phones.
● If you are using either a private branch exchange (PBX) or an integrated
services digital network (ISDN) converter/terminal adapter, make sure the
HP all-in-one is connected to the port that is designated for fax and phone
use. Also, make sure that the terminal adapter is set to the correct switch type
for your country/region, if possible.
Note that some ISDN systems allow you to configure the ports for specific
phone equipment. For example, you might have assigned one port for
telephone and Group 3 fax and another port for multiple purposes. If you
continue to have problems when connected to the fax/phone port, try using the
port designated for multiple purposes; it might be labeled "multi-combi" or
something similar. For information on setting up your HP all-in-one with a PBX
phone system or ISDN line
you may also refer to the manual for this unit here
if you go there please refer to page 82 of the manual or chapter 10
Aug 02, 2008 | HP Photosmart 2710 All-In-One InkJet...
HEADSET
A button must be programmed as a "headset" key. When activated, it will lamp red, and put the conversation on the headset jack under the phone (next to the handset jack).
Or you can purchase a headset with an auto lifter for the handset. It picks up the handset enough to answer the call, but transfers the conversation to your headset.
Apr 14, 2008 | NEC DTU 8D-2 Corded Phone
FAX PROBLEM
Not sure if my previous solution was posted or not.
The small cord that came with the printer is a special two conductor cord. You must use tis cord or equivilent.
Go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00014834&lc=en&cc=us&product=421991&dlc=en
Mar 10, 2008 | HP OfficeJet 6210 All-In-One InkJet...
I am trying to add phones to my Lucent / AT&T Partner system but they do not have dial tone.
No, you will need to have the company come back and "liven" up the jacks.
Sometimes there are not enough ports of the phone system to connect all the wall jacks to the system. So it is possible that you have to expand your system.
Dec 14, 2007 | Lucent PARTNER18 Corded Phone
Computers & Internet Logo
43 people viewed this question
Top The Computers & Internet Experts
Carl Rick
colinat108
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
