Afficio450 replace new developer unit wat procedure to be follow?
I have afficio 450 copier .. i replace dv unit w/ a surplus unit... but i stil have a light copy output...is der a ader procedure to performor to follow how to replace dv unit...
wat i did...
1.Pull-out the old dv unit
2.Cleaned the surplus dv unit by removing all remaining developer
3.Put a new developer in the surplus unit
4.Insert the surplus dv unit in the machine
5.Put a piece of paper in the dv hole wer the toner enter
6.Power on the machine,performe 2801,2805,
7.turn off get the piece of paper wer the toner enter
8.power on and test the copy....
9.the copy is not good its stilhave a light copy..
10. Is the dv unit i bought is damage?
  • 2 more comments
  • thraser
    thraser Aug 03, 2009
    i olridy solve the problem.. my toner motor is malfunctioning...the rotate is not accurate i change it w/ a new 1... if i wil change my drum unit is der nid to be calibrate...run 3001,2805 is in the packaging instruction ...if i wil folow dis procedure it wil not afect the calibration of my dv and toner? any sugestion or Comment?
  • thraser
    yup i always do dat and also cleaning the hole pcu ...if i wil change the drum unit wat procedure i must folow?.. in the packaging the intruction is run 3001,2805 if i wil folow diz intruction it wil not afect the calibration of my dv and toner....
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    How is the drum & primary charge unit? How about the transfer? If you put a know good developer unit in and the copies are light... It is not the developing unit.... How about the drum ground... How about put all the setting back to "Door Spec's" Good Luck
  • Anonymous May 11, 2010
    Have you cleaned the laser optics, and filter glass, as well as the scanner optics?
  • 31 Answers
No, the 450 is just one of those machines that seem to have PCQ no matter what you do. Given light copies, I'd replace the drum for sure and make sure your ID sensor isn't covered with toner. Dust covered optics will also cause light copies on this model.
Posted on Jul 26, 2009
Afficio 450 developer type 4 or type 5
This machine takes Part Number "887733: Developer Type 5"
Hope this helps.
Jul 05, 2009 | Ricoh Office Equipment & Supplies
Changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Apr 24, 2009 | Ricoh Aficio 450 Copier
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Did you use a vaccum on the developer unit???? You may have blown out the ATDC sensor on the developping unit
Afficio 450 is der a sensor in toner supply
Do you know how to calibrate the toner/developer sensor?
Jan 26, 2009 | Ricoh Aficio 450 Copier
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Changing developer in afficio 450
Preform SP 2-801 then 2-805.That will do it!
Jan 21, 2009 | Office Equipment & Supplies
Change the developer in afficio 450
To remove the Dev. unit.
1. Open the right upper cover and front cover.
2. PCU. (☛ 3.11.1)
NOTE: Spread paper on a clean flat surface that is free of pins, paper clips,
staples, screws or any other metal objects.
3. Loosen [A] (! x1)
4. Rotate bracket [B] left.
5. Development unit [C]
NOTE: Pull slowly to avoid scratching or nicking the development roller.
6. Set the development unit on the spread paper.
7. If you are temporarily installing a used development unit for test purposes,
perform SP2-220 and 2-802-1 after installation (☛ Chapter 5, “Service Tables)
Replacing the Dev. material.
1. Development unit (☛ 3.12.1)
2. Remove the development roller (☛ 3.12.3)
3. Empty toner [A]
4. Turn drive gear [B] to ensure that no developer remains in the unit or on the
developer roller.
NOTE: Dispose of the used developer in accordance with local regulations.
Work carefully to avoid scratching or nicking the development roller.
5. Pour approximately 1/3 of the developer [C] evenly along the length of the
development unit.
6. Rotate the drive gear [D] to work the developer into the unit. Repeat [C] and [D]
until all toner is in the unit and level with the edges.
7. Reassemble the development unit
8. Cover the toner entrance hole [A] with a piece of paper.
9. Install the development unit in the machine.
10. Turn on the main power switch, make sure that the machine has warmed up,
then perform the TD sensor initial setting using SP 2-801.
NOTE: When performing this setting, cover the toner entrance hole with a
piece of paper. This prevents used toner falling from the PCU into the
development unit during the TD sensor initial setting and interfering
with the Vref setting (toner density reference voltage).
11. After performing the TD sensor initial setting, remove the sheet [A] from the development unit.
This is how you replace and reset (calibrate) the new Dev. material.
Jan 20, 2009 | Office Equipment & Supplies
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
173 people viewed this question
jasbo
jasbo
