Question about The Office Equipment & Supplies
I have reflecta diamator A slide projector. The slide positioner piece that fits in in front of the bulb from the top is missing.Any help?
xscrewdriver
  • 246 Answers
SOURCE: Missing piece, camera will not turn tape
the pinch roller goes here:
you are missing the snap spring too, which is used to lock the pinch roller.
Posted on May 21, 2009
SOURCE: plastic pieces missing from the railing on the crib
please contact rockchic730@yahoo if you need detailed instruction on christina model 8996crp. i have the manual and i would be happy to help you out.
Posted on Aug 30, 2009
  • 412 Answers
SOURCE: I'm having trouble changing the bulb in a Kodak
First of all, verify you are using the correct lamp: it should be a 120volt, 300watt, ANSI Code "ELH" lamp. (This may seem too basic, but you'd be surprised at the number of people who try the incorrect lamp).
If the lamp is correct and you can not insert it by pushing the base of the lamp into the terminal connector relatively easily, then chances are you have a build-up of material on one or both of the lamp contacts caused by arcing (arcing is caused by loose lamp terminal contacts). If this is the case, then you need to replace the lamp terminal assembly (the ceramic-like white piece the lamp terminals should slide into). You should still be able to buy a lamp terminal assembly for your Ektagraphic AF-1 from: www.micro-tools.com
Good Luck !!
Posted on Nov 12, 2010
  • 412 Answers
SOURCE: Kodak 410 Projector/Viewer - no lite through projector or viewer
These projectors were designed & made by Telex for Kodak.
If the screen stays black when you push a slide down into the "gate" (in either viewer or projector mode), then the trip mechanism that opens the shutters when a slide is detected has a problem. It could be an adjustment, a broken or out of position spring or hardened lubrication.
There is no good way to proceed unless you are trained in the service of these projectors. Contact a factory-trained repair dealer. Happy New Year!
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: I require a bulb for a Braun Paximat slide
Try checking with www.bulbman.com They have an amazing assortment of lamps for projectors!
Posted on Feb 28, 2011
I opened my emp x3 because it wont turn on. there is some kind of strip that runs from the cover and seems to connect to the main board but it is disconnected, is that the problem? Where would I connect...
The wiring strip you are referring to runs from the control board on the top of the projector to a slot connector on the big circuit board below. That connector is on the edge of the big board facing the front of the projector, about two inches from the left (when facing the projector front). You'll know which one it is because it has black piece on top of it that pulls up. To reconnect the strip, pull up the black piece and slide the blue bottom part of the strip in the slot opening on the front of the connector. Then push the black piece back down.
Nov 25, 2010 | Epson EMP-X3 LCD Projector
MODEL 760h WILL NO LONGER ADVANCE SLIDES
The KODAK Carousel 760H was manufactured approximately between 1971 & 1981.
The problem you are describing is most likely a broken cycle solenoid "link". This "link" connects the cycle solenoid and the slide change mechanism. Repair parts are still available, but this is a repair best left to a factory-trained technician. Contact an Authorized Repair Dealer.
Jul 25, 2010 | Kodak Carousel 4400 Slide Projector
I'm having trouble changing the bulb in a Kodak Ektagraphic AF-1 slide projector. The bulb doesn't fit easily into the housing and I don't want to force it.
Good Luck !!
May 20, 2010 | Kodak Ektagraphic III E Plus Slide...
No power after replacing bulb
The solution from bjwjb posted on Dec 30, 2009 is absolutely correct:"There is a piece on the bulb cover panel that you take off in order to change the bulb that fits down inside the bulb assembly when you put the panel back on. The bulb cover panel and the part of the panel that goes down into the bulb assembly must be present or the projector will not power up (there will be no lights either)." I would add to that once the cover is placed back, but before the screws of the bulb cover are tightened, firm pressure should be place on on the bulb cover panel on the spot placed where the plastic protrusion (a plastic "stick" about 1.5 inches long that fits into a void in the bulb assembly) goes into the bulb assembly. You should/may hear a "click", indicating that the protruding plastic piece has been fully inserted into the bulb assembly and makes contact with whatever contraption is inside the assembly to enable power-up. If no pressure is exerted the plastic protusion may not extend down far enough to make contact to enable power-up. In such case the bulb cover panel may be slightly bulging in the location of the protrusion. You would still be able to tighten the bulb cover panel screws, because the plastic is flexible. In such case you may find that the screw closest to the location of the plastic protrusion may need pushed in more. In this condition, even though you may think the cover is properly placed, the plastic protrusion is not fully inserted and does not make contact and there are no lights or power. Just take of the bulb cover panel place it back following the instructions above.
I had already disassembled my projector and was ready to bring it in for service when I did an internet search and saw the advice from bjwjb. Thanks very much!
Nov 14, 2009 | Optoma EP739 Multimedia Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
I'm trying to replace the lamp
all [parts small or large are in place for a reason and if it does not go back on then the chances are that yu have the wrong bulb as this is a common occurance. also you will have a counter for the bulb hours on the inbuilt menu on screen, this will need resetting for full functionality to be returned.
Feb 25, 2009 | InFocus Proxima DP6155 Multimedia...
How do I replace a front headlight?
remove the three bolds and one nut holding headlight housing in place. pull out housing turn bulb plug counterclockwise till bulb comes out replace bulb and reverse process to re-attach housing.
Dec 27, 2008 | 2000 Toyota Celica
X1a brownish bar on right side of screen
Hi mate.
This is caused by a light tunnel fault, where infocus designed a stupid light tunnel using 4 pieces of mirror and some very tacky glue. What happens is that, over time the glue comes off causeing one of the pieces of mirro or more to collapse giving you the shaded effect on one part of the screen. I myself have had this problem and am now in need of a new light tunnel as mine literally broke, but here is a thread that tells you very efficiently (picture guided) on how to fix this problem. BUT be aware that you need a very good glue and something that will withstand the heat, thats where I went worng lol.
http://www.avsforum.com/avs-vb/showthread.php?t=618877
Hope this help, if you need any help just let me know as I have dismantled mine right to the core and put it back together faultlessly many times now so can practically do it with my eyes closed lol.
Cheers
Russ
Feb 10, 2008 | InFocus X1A Multimedia Projector
29 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
