Question about Grilling
I bought a natural gas grill and was delivered on 5-2-17 by pilot trucking.The box was damaged.The Grill Body Assembly was broken and dented. Model #GR2210603-MM, Item #638568999.I need a another one.
    Top Expert:
  • 15,465 Answers
Notify the seller of damage and make request for a new one
Posted on May 02, 2017
Just bought a Weber Genesis II LX Model S-340 Natural Gas Grill. The plumber installed a 54' line, 1" in diameter. The grill will only heat up,to 400 degrees. What could be wrong?.
If he really installed a 54 foot line instead of a 54 inch line, the line is way to lone. The gas pressure isn't high enough to supply enough gas to the grill to get any hotter.
Oct 19, 2017 | Weber Grilling
I need to get a Grill Body Assembly for model#GR2210603-MM for the one that was damaged when Delivered on 5-2-17.
advised before need to notify seller and request replacement or if you want to replace part notify manufacturer for replacement
May 02, 2017 | The Video Game Consoles & Games
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Grill will not light
I assume the grill is configured for natural gas (propane generally requires a different pilot orifice unless the owner's manual states otherwise; they are not interchangeable). The following is written as a generic explanation; see your owner's manual for a diagram of the internal gas piping. If you need further assistance, please ask in the comment box. If you do not have a sediment trap in the gas piping, the pilot tubes may be clogged with white sediment similar to the lime from tap water. In this case, you will not be able to smell any gas at the pilot outlet. The clog is usually right at one or both ends of the tube, inside the fitting. It is important to get both ends properly tightened after repairs. The end connected to the supply obviously needs to be tight for safety, and the flame end needs to be tight to maintain proper pressure for the flame. Test with soapy water; there should be no bubbling when it is applied to the connection.
Jun 27, 2014 | KitchenAid KBNU367VSS Gas Grill
Kenmore grill 146.23766310
Here is the owner's manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/1212186L.pdf
In it, it states, "Use grill, as purchased, only with LP (propane) gas and the regulator/valve assembly supplied"
Oct 30, 2013 | Grilling
Can a Turbo STS 3 burner grill (720-0057-3b) be convert from natural gas to propane? Barbeque Galore has gone bankrupt and does not offer any assistance at their 1 800 number and I can't find any...
The original BBQ's Galore went bankrupt, but was bought by new owners, who still operate it as BBQ's Galore. However, they did buy any of the older company's parts supply. However, all you need are the burner orifices for each burner (including the rear burner) and a Hose/Regulator Assembly to connect the grill to the grill tank. Follow the conversion instructions in the Owner's Manual (see link below) and you should be able to do it.
http://www.grill-repair.com/images/grill/turbosts.pdf
I suspect if you call BBQ's Customer Support 800-752-3085. They can provide the orifices, as they are universal in fit. The Hose/Regulator Assembly can be purchased from any hardware store or home improvement center that sells grills and accessories, for about $30.00.
Once converted, you will see marked improvement in the heating capacity of Propane Gas, as opposed to Natural Gas. The grill will preheat faster and maintain higher temperatures longer.
I hope this helped you, Bradley and thanks for choosing FixYa. Happy Grilling!!
Aug 10, 2011 | Barbeques Galore Turbo STS 4-Burner with...
Natural gas grill won't light with match. Gas side pilot will light but not main grill. Help- we have a lot of company.
Check the valve and jet. The chances are that the jet is clogged. Depending upon where you have stored the unit, the jet may be clogged by a spider that was attracted to the odor of the natural gas.
Should be an easy fix.
Let me know if you have any problems or questions. Thanks.
Jul 16, 2011 | Ducane Grilling
BOUGHT A BRINKMANN 2545 GRILL LAST NIGHT. WE HAVE IT ATTACHED TO GAS LINE COMING FROM HOUSE. GRILL WILL LIGHT BUT IT IS A LITTLR FLAME AND THE OTHER BURNERS WILL NOT LIGHT?
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Jenn Air 740-0141 LP to NG Conversion
If the grill can be converted, it's usually a matter of providing a source for the natural gas and then changing the gas jets for the burner(s) and possibly a regulator, depending on your model. Some grills may require changing the gas burner valves themselves. Kits are usually available from a dealer unless the unit is old.
The natural gas jet will be slightly larger than the propane jet because natural gas doesn't have as high a heating value as propane.
If you do this, check your new conversion for any leaks using a soap solution in a spray bottle.
Just be aware that the grill may not get as hot with natural gas and cooking could take a little longer, but should still work just fine.
Your natural gas line should typically be about 1/2" unless it's huge or is over 50-60 feet away from the grill location. If so, use a 3/4" line. Piping material and methods are usually governed by your local building codes.
Mar 17, 2009 | Thermos Stainless Steel Gas Grill
Grilling Logo
98 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
