Question about Cameras
After the movement, what coordinates will the drum major be standing on?
A marching band stands in a triangle formation. The drum major stands at A, one of the vertices of the triangle. The whole formation marches 3 units left and 5 units up. They then march 2 units left and 2 units up.
  • 12 Answers
SOURCE: need codes for eorovox 5c 01, march 4th please
00=0B F2 52 72 4E 1B 86 90
01=83 61 00 3A FD F3 DC 0A
Posted on Mar 04, 2009
  • 71 Answers
SOURCE: laptop problem
you can try this: unplug from power, remove battery, press power button for about 30 to 60 seconds, connect back to power leave battery out, turn power back on. see if that works.
Let me ask you this, when you turn the power on: do you see or hear the hard drive spinning?
let me know if it works,
good luck
Posted on Apr 10, 2009
  • 567 Answers
SOURCE: red triangle on left hand top corner - K800i
triangle means roaming if its a red triangle then your internet is turned off while roaming
go to options>mobile network> data services and select what setting you would like either on all the time, off, or off while roaming
solid triangle means extended network (coverage with another carrier that your service provider has an agreement with). some services might not work
blinking triangle is roaming (on a network with no agreement)...most carriers have simply disabled roaming entirely, you either get their network, or extended network to avoid additional charges. int'l roaming is different, not restricted. if you're near either of the borders, i'd say choose "home only" under network options to avoid int'l charges
Hope that helps
Posted on May 25, 2009
  • 586 Answers
SOURCE: two inch wide vertical band spreads across half of screen
The problem is in vertical section and the faulty components are :
1- Capacitor
2- Transistor
most probably the poped capacitor must be the reason, check and replace the faulty components.
Thanks for using fixya.
Posted on Jul 01, 2009
  • 17130 Answers
SOURCE: This fan is the Aloha
You are still in the warrranty period of one year and it is most adviceable not to tamper it so as to lose the priviledge.
So please get in touch immediatley with your dealer.
Only If there is no help do you need to open the base and check the leads from plug to the motor for continuity. if voltage is present then motor may be faulty.
Posted on Sep 14, 2010
Height of bandsaw without stand
What's the unit of your band saw? There's a metabo unit that has 925mm working height without stand.
Jan 20, 2013 | Metabo Saws
Need to identify and find parts for the Pearl FZH725/C85 Drum Kit. It was delivered with missing parts. Specifically Floor tom, 14" tom and arms to hold it. Need some direction and guidance, thanks.
I am a drummer as well in a classic rock band. Most the time when I need a part for something for my drums. I will go to guitar center. But to save money eBay is your best bet. You go to guitar center to make sure you have the right part, but don't buy it there . Match it up and go to eBay, lot of drum companies use eBay to sell there stuff. Thanks mike
Jul 22, 2011 | Pearl Forum FZH725/C85 Drum Kit, Zenith...
An army contigent of 616members is to march behind an army band of 32 mebers inaparade.the two group are to march in the same number of columns. what is the maximum number of columns in which they can...
being in the millitary you cant form a formation more than 6 columns but we dont care about the extra straglers tagged to the end.
does this include squad leader? squad leader removes one person from each formation and they call out marching orders and cadance.
but for your question
the common factors of each number is
2,5,3 (32)
2,2,2,7,11 (616)
you take it from there.
Jun 11, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Rigid 14" Band Saw Stand Bounce
Yes, take it back to the store that sold it and get them to replace or repair the problem. Hope this helps!
May 04, 2010 | Ridgid 14" Band Saw with Stand
Kick stand on a yz400f
maybe. if it looks like a triangle with a bar turned at a 90 degree angle fits inside the frame of the bike
Jan 08, 2010 | 2004 Yamaha YZ 450 F
LE stands for locked motor error..
1 . check the connections to the Coil/Stator at the rear of the unit possible broken wire.
2 . Coil/Stator Assembly is defective hence no drive
Dec 15, 2009 | LG WM-2277HW Front Load Washer
Bike stand doesn't return
Yes , it may require some light lubricating at around the stand but first you will need to clean up throughly around the stand fittings better to use WD40 and thn some mineral oil as lubricant.
Not bad too to check the spring of its tension!
Hope this helps!
May 12, 2009 | 2004 Honda CBF 600
Does anyone have the table top stand for sale ? tia
You can order a replacement stand assembly for this model (P42H401) from a major Hitachi parts distributor at the link below:
Hitachi P42H401 Replacement Part Stand Assembly / Table Top Stand
Apr 15, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Cobra 757 codes
X stands for wide band radars(easy to detect,lots of false alarms)
K/Ka stands for pulse band radars(similar signal has auto doors)
W,L stands for laser detection (very little false signals)
Ku stands for signal most used on speed cameras
V stands for radar detectors detector
Have in mind that you can only lower your speed 20-30 km/h in city zones, and up to 50 km/h on highway.This depends on car,brakes and You.
Jun 16, 2008 | XRS-757 Radar Detector
Canon power shot S3IS
Apparently this is not the camera for marching band stuff at night because I had this problem over the weekend!  I tried everything...
Oct 18, 2007 | Canon PowerShot S3 IS Digital Camera
Cameras Logo
75 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
