Question about Dometic Heating & Cooling
My dometic rv ref makes on & off sound like something running for about every 5 seconds what can this be? gets annoying.
    Top Expert:
  • Dometic Master
  • 8,514 Answers
Cooling fans behind unit
Posted on Sep 11, 2017
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
VtToolMan
  • 704 Answers
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
  • 332 Answers
SOURCE: I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Posted on Mar 05, 2010
  • 332 Answers
SOURCE: Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Posted on Mar 08, 2010
Dometic fridge NDR1292 in RV has started to make a hissing noise at least once a day for about 5 seconds. Also, cooling fins are icing up very quickly, every few days. Does something need replacing?
NDR 1292 amish style cooling coil replacement - YouTube
? 8:13
www.youtube.com/watch?v=Ru6lFABsqnk
Oct 13, 2012 - Uploaded by taintedcrimsonwings
Step by Step instructions for replacing a Dometic NDR1292cooling unit. ... RV Refrigerator Cooling Unit Replacement Part #2 Installing The ...
Sep 27, 2015 | Dometic NDR 1292 Refrigerator
Installing a Dometic single zone LCD Thermostate in my rv. Getting a code E1. Everything seems in the right place. Is there something the instructions for got to mention? How do I get it to work?
Try this.
Turn off thermostat. Wait for no display on lcd.
Hold + and mode at same time for 3 seconds.
Lcd should display - -
Turn on as usual.
If that dosnt work you have a cabling issue between thermostat and main board. Possible bit rare component failure. If all is installed correctly.
Jun 14, 2015 | Dometic Rooftop RV Air Conditioner
Dometic refrig not cooling but found yellow oil at service panel
if you find an oily substance its most likely freon. this looks pretty new so i would say you have a bad soldered joint on a copper to steel line. theses usually ar fot the high side. where the condensor coil or loop runs either to underref or up in the ref walls
Aug 01, 2010 | Dometic RM2652 Refrigerator
I have a duotherm rooftop ac. fan runs fine but when comppressor starts it runs for 5 or 10 seconds and shuts down
I'm not familiar with these units so this is very general. Your compressor could be shutting down due to low pressure. You would need to get the refrigerant charge checked. It might be due to an overload tripping, which would then reset itself. If you had a schematic or something to send me I could tell you more.
May 05, 2010 | Dometic Rooftop RV Air Conditioner
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
But first
Sep 23, 2009 | Dometic RM2852 Refrigerator
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
Open Questions:
Heating & Cooling Logo
48 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
