Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Soap dispenser drops soap out and tablet does not disolve.
  • 52 Answers
Use liquid soap ...those tablets are less messy but they don't work very well ....and make sure to use a dry agent like "jet dry"
Posted on Jul 25, 2009
2 Suggested Answers
  • 195 Answers
SOURCE: the soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Posted on Dec 13, 2011
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Soap dispenser opens, but detergent doesn't disolve and runs down front of door. Have tried several different detergents with no result.
You may have a hot water problem. The water when hot will disolve
the soap or detergent. The dishwasher hasits own heater to heat
the water entering the dishwasher. Check the electrical connections
below the dishwasher to make sure your heater is working. It may be just
a loose connection.
If this is not the case, then a service repait man will need to be called,
to determine why it is not heating the water.
Feb 25, 2011 | Maytag Dishwasher
Soap tablets are not disolving in the drawer?
Unlike a dishwasher the drawer on a washing machine is for soap powder or liquid. Tablets won't dissolve in the drawer you need to put them in the drum if at all.
Dec 13, 2010 | Washing Machines
Soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap dispenser is not releasing and the water is not disolving the soap; thus the dishes are not getting clean
if you are using tablets as opposed to liquid then just put them in cutlery basket at beginning of cycle wash result will still be the same, probably wax valve has failed these do go often and will need new dispenser or wax valve service engineer will need to change
Oct 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The soap isn't fully disolving and the dishes on the top rack are looking like they haven't been touched.
Make sure your water temp is 140 degrees
make sure to use only FINISH Tablets
make sure the telescoping arm in the center of the dishwasher lifts fully and drops under it's own weight
make sure the wash arm on the bottom of the tub spins freely.
Oct 24, 2009 | Dishwashers
My Maytag neptune washer has a bad odor that seems to be transfering to the clothes. What can cause this and how do I correct it.
on the front load machines there is a large rubber door boot which gets built up with soap scum. always leave the door open a little bit when the wash day is done. there is a product available called "Afresh". it comes in a pkg with 3 tablets. if the odor is strong follow the directions and use all three tablets. then for maintenance use one tablet a month in an empty machine. what also helps is to make sure you do at least one hot water only wash per month, this helps to disolve all the soap that gets built up in the dispenser tubes and drain hoses etc. hope this helps.
Oct 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Powdered dishwasher detergent stays stuck in dispenser after wash
There is a rather delicate mechanism which controls that soap door. Often this is the first part of a dishwasher to cause trouble. Instead of using the powdered detergent in the soap holder just pour the measured amount into the floor of the machine.
Once you have used up the powder, you might wish to consider a tablet which also just gets tossed.
Sep 18, 2009 | Dishwashers
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Dispenser door
Remove the outer door panel and check the actuator for the soap dispenser door it is probably broken. You might also check and make sure you don't have an old soap build up inside the soap dispenser. Sometimes old soap builds up and dries inside the dispenser and causes the door to stick. It should be free. Good luck.
Dec 21, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
158 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
