Question about Dishwashers
While running customer service program, display locked up and I cannot reset back to normal function. Normal resetting of the breaker did not solve issue.
SOURCE: runs program but stops on 1 minute left and needs resetting each time
Did you manage to solve the problem with your dishwasher. I have the same model and it keeps sticking on 1 minute at the end of the cycle. Any advice please?
Posted on Sep 30, 2007
SOURCE: start button on the HMI won't work
There is a ribbon cable that connects to the control panel. Mine was operating the same as yours. I opened up the front and reinserted the cable and its been fine ever since. you need to take all the screws out from the door panel inside the washer to geet to it.
Posted on Nov 17, 2007
tborn6
  • 700 Answers
SOURCE: 3-pole 60 Amp Circuit Breaker is tripped and won't reset.
check ot see if its on a shunt trip system. what it means is that in order to reset the breaker you have to see what made it trip. Look for a 115 volt breaker that is tripped in the panel that serves tha line. good luck.
Posted on Jan 25, 2009
SOURCE: Fisher Paykel displays F1 error and will not stop
fisher paykel displays F1 error and will not stop running, How do I reset.
Posted on Jul 03, 2009
SOURCE: touch screen is not working
not working touch screen
Posted on Jun 25, 2010
98 Oldsmobile Aurora There's a on my Dash it says information center and has the oil fuel speed all that it says low oil is there any way anybody knows how to reset that
Check your engine oil using the oil dipstick located on the engine - you need to add oil to the fill line as shown on the dipstick. You should have the oil replaced regularly (every 3-6 months) and keep your eye on the level if the engine is leaking oil underneath or burning a lot of it.
Mar 08, 2017 | Oldsmobile Cars & Trucks
How to format HTC Touch2 t3333?? need help
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your phone is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
To perform a soft reset
1. Remove the back cover.
2. Remove the stylus to reveal the RESET button that is located at the bottom of the stylus compartment.
3. Use the stylus tip to press the RESET button.
Your phone restarts and displays the Home screen.
4. Replace the back cover and insert the stylus back into its compartment.
Oct 11, 2013 | Cell Phones
My residential schlage cobra lock no longer locks. I have checked the batteries. Using the programming instructions, I cannot get a "normal' code to program. I always get flashing lights...
Since you seem to be doing everything properly and following the instructions, I recommend that you contact Schlage for some technical assistance. Here is the contact information:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ:
http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Aug 04, 2011 | Schlage COBRA by Keyless Lock
Hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
How to remove align screen
Hi..
Problem can com from your touchscreen panel.
you need to replace it manually. only then this will be solved.
or you can try with soft reset or hard reset.
please find explanation at below :
i-Mate JAQ3 soft reset
Resetting Your Pocket PC Phone
Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
A soft reset is also necessary after the installation of some programs.
will be lost.
You can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
system problem. After a hard reset, the device is restored to its default
settings - the way it was when you first purchased it. Any programs
you installed, data you entered, and settings you customized on the
device will be lost. Only Windows Mobile software and other preinstalled
Remove the battery cover and using the stylus, press on the small
button to the left of the battery. Otherwise simply remove the battery,
wait a few seconds and then insert the battery again.
To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
i-Mate JAQ3 hard resetHard reset using Master Clear
1. Tap Start > Settings > System tab > Master Clear
2. On the System tab, select the Master Clear (!) icon
3. Proceed to enter the confirmation code: 1234 and push reset button,
system will auto reboot to complete the operation.
hope this kind information will be help you to solved
regard,
adhiwahyudy
Dec 24, 2010 | i-mate JAQ3 Smartphone
Touch screen not working. mobile getting automatically restarted time to time.
It needs a reset.
This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after theinstallation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
Hard reset
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings - the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost.
To perform a hard reset
  1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
  2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
  3. Release the TALK and END buttons, and then press ENTER on your device.
Aug 03, 2010 | HTC Touch P3450 Smartphone
Phone is stuck on setup
If it is stuck or frozen:
Do a Soft reset
Occasionally, you may need to reset your device. A soft (or normal) reset
of your device clears all active program memory and shuts down all
active programs. This can be useful when your device is running slower
also necessary after the installation of some programs. If a soft reset is
Or:
Do a Hard Reset
(THIS WILL REMOVE ALL APPS BUT NOT YOUR PICS AND MUSIC!!)
  • Slide open keyboard
  • Press Alt and L at the same time you will get a screen with some options listed
  • Press Alt and W at the same time to wipe device to factory reset
  • Once it is finished press home and back key at the same time
  • Remove the battery
  • Reinsert the battery
This will wipe your device to factory reset. You will need to log in to your gmail account like you initially did.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 16, 2009 | HTC G1
How to do factory reset of i-mate JAQ
will be lost.
settings — the way it was when you first purchased it. Any programs
i-Mate JAQ3 hard reset Hard reset using Master Clear
Thanks, Joe
Jun 02, 2009 | i-mate JAQ3 Smartphone
I downloaded a bunch of ringtones and a few wallpapers to my phone. Today the screen went out on me. I can't see the screen to delete the stuff out or to reset it. What do i do
Occasionally you may need to reset your Pocket PC Phone. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when the device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset:
o Use the stylus to lightly press and hold the RESET button on the bottom of your device. The device restarts, and then displays the Today screen.
Warning! Always turn off your device before performing a soft reset or installing/replacing the battery.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on the device will be lost. Only Windows Mobile software and other pre-installed programs will remain
To perform a hard reset:
  1. Press and hold both soft keys on the device. Keep these keys pressed, and at the same time, use the stylus to lightly press and hold the RESET button on the bottom of your device.
  2. Release the stylus but keep the soft keys pressed when you see the following message on your device screen. "Do you want to erase all user data and restore to manufacture default?" will appear.
  3. Slide open the hardware keyboard, and press R to restore to factory default or press X to exit the hard reset process.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Mar 03, 2009 | UTStarcom Blitz Cell Phone
Hard reset
Occasionally, you may need to reset your device. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile software and other pre-installed programs will remain.
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
  1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Oct 29, 2008 | HTC P3300 Smartphone
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
Owen Barnes
