Question about Dishwashers
My diswasher becken shows err 2. Water stays in and dishes are dirty. Anyone know what err 2 means?
  • yadayada
    yadayada May 02, 2017
    Since you gave no make or model number can't assist.
catriver
  • 878 Answers
SOURCE: Bosch Diswasher not draining
Soyben, you need to check to see if either the drain hose or syphon break at the sink is clogged. The drain motor on this model is not a bilge pump that will remove water from the base. Therefore Im leaning on a restriction somewhere. Other than that you may have to check for debris in the drain sump. Check these areas out first...Catriver...post back
Posted on Aug 27, 2006
  • 360 Answers
SOURCE: GE Profile PDW7300, Leaves 2 - 3 inches of dirty water in bottom
check for a clogged discharge hose where it connects to the plumbing under the sink...this is the most common area for a clog. if no restriction is found, the discharge valve will need to be tested
Posted on Feb 20, 2009
Healeyman
  • 1198 Answers
SOURCE: dishes not clean enough. as if rinsing in dirty
If your dishwasher drains it's water to a garbage disposal, give the disposal a spin while the dishwasher is pumping out. Check around the bottom of the dishwasher to make sure something is not clogging the drain.
Posted on May 01, 2009
Typus
  • 69 Answers
SOURCE: Error message on TI-83. What does it mean?
It means that you have put the wrong things together. E.X. String>Equ(x,y) when x dont equal a Yvar. and y dont equal a string number (StrZ, Z=#'s 0-9)
Posted on May 13, 2009
MNfisherman
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
What is the most effective soap for thw Miele G870SC diswasher
the only dish detergents that work right now are the miele tabs, and finish has a product called finish all in 1 powerball. everything else on the market right now will leave your dishes dirty, and will leave residues behind making your glasses cloudy and your dishes dull. describe the noise better and i will try to help.
May 31, 2012 | Miele 24 in. G870 Built-in Dishwasher
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
DIrty Dishes
try running it through empty with some cleaner in it check all the in side for anything clogging it and then if you can put some hot water in it to loosen any grese
May 26, 2010 | Hotpoint HDA2000G Built-in Dishwasher
Why does the diswasher not clean top rack of dirty dishes? It does not seem to be getting any water.
Check if the top sprinkler arm sprinkles any water. If it got some years the screw on which holds the arm might be worn out and that could, depending on the model, result in water only flowing straight down to the second arm. Or the sprinkler arm could be clogged, I would check it out anyhow.
Mar 06, 2010 | Dishwashers
Dishes are still dirty ...8 year old Maytag usually works good...recently is doing a poor job
Have you tried :
-Increasing the water temperature?
-Changing you dishwasher detergent from a powder to a liquid?
-Using a longer cycle?
-Using diswasher cleaner? I find that this is usually the answer. You can buy it in the grocery store where they sell dishwasher soap and rinse aids. Read directions and follow closely. If you have hard or well water you may want to do this more often then the package directs. Depending on how bad the calcum buildup it may take a couple tries to clear up the dirty dish issue.
Dec 25, 2009 | Dishwashers
Dishes still dirty after wash cycle
It would be real helpful to have you provide the manufacterer and model number to get more specific with solution.
-Have you changes dishwasher soap powder recently? Buy a box of Electrosol or Cascade and see what happens. The ultracheep versions actually have caused cleaning problems, especilly in water-conserving dishwashers.
-Under the lower rack is the sump area with a filter that can be removed, usaully by removing several screws. Pull that filter, rinse is as best you can. Inspect under where the filter was and remove all debris. Watch out for broken glass that is found in most well used diswashers, it is hard to see and sharp! Reasemble the filter.
-If problems continue and if this diswasher is several years old, plan on getting the wash pump motor replaced (or replace the diswasher with a name brand, Energy Star model.) Good Luck!
Please update me with what you found. OK?
Mar 30, 2009 | Dishwashers
Dirty dishes on lower rack
Please confirm that you own an LG LDF7811 dishwasher and it is not cleaning properly.
-Are you getting any error codes displayed? -Did you remove the mesh filter and clean any debris beneath it plus rinse out the filter itself?
-Are you using a name brand diswashing powder? Avoid ultra-cheap detergent, especially in water-conserving units like the LG 7811. Never use DW gel or tablets in any dishwasher.
-Do not over rinse the dishes before placing them in the DW. The food granules actually are used to clean all the dishes before being rinsed away.
Please try these suggestions and reply to this message with what worked best and if the problem continues. Good Luck!
Aug 25, 2008 | LG 24 in. LDF 7811 Stainless Steel...
My soap dispenser does not open properly and soap streaks on my door and detergent is always left over in tub no dishes are cleaned any suggestions?
ck water level ..i assume you mean diswasher water should be almost to bottom of float..if water ok are you sure main wash motor working
Aug 04, 2008 | Maytag Washing Machines
Timer Knob Smegdishwasher sa 620x
I have this same model Smeg dishwasher. 1 = Soak - pans and dishes awaiting completion of the load. 2 = Strong - Very dirty pans and dishes dirt dried on. 3 = Normal - Normally dirty pans and dishes. 4 = Rinse - Dishes requiring "refreshing". If you would like a full copy of the user manual, send your address to "brockjack@g-node.com.au" and I will photocopy our manual for you.
Oct 06, 2007 | Smeg CSU2001 Built-in Dishwasher
Diswasher detergent door
lizzie1 First thing check if the lower dish rack is in right position. If it is in wrong position it is not enough room for the lid to pop up open. Try to turn the dish rack around and see if it works. If not, then I'll need the full model number for your dish easher. Gendos...post back
Jan 28, 2007 | Whirlpool 24 in. DU850DWG Built-in...
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
