Replace front panel (broken push bottom on/of switch) and replace remote control(lost) AC model EP104249 (where I can order ?)
    Top Expert:
  • Televison & ... Master
  • 77,499 Answers
Posted on May 02, 2017
I have a voltas vertis AC a model which only has on/off switch on the panel. There is no button to control temperature or anything on the panel. I have lost my remote and unable to get it from market. Is...
You can't adjust without remote. Please tell your A/c model number i will advise you where the remote is availbale. And also any of voltas dealer can help you to get it.
May 02, 2014 | Heating & Cooling
How to use haier ac without remote
open the air filter cover(front panel) on your air conditioner... usually you will find a small button to switch on... it's small spring switch, push it ones it's on, push again then it's off.... you can replace this switch with relay... now you have it...
Aug 28, 2013 | Haier Heating & Cooling
The remote control for my Zenith XBR413 is lost. Where can I find a replacement?
Model # IS 4070
AM/FM Stereo Receiver
With Phonograph and Cassette Play/Record
Serial # W288209
Power Source AC 120 V 60 Hz
78 Watts 0.65 Amps
Unswitched
AC 120V 60 Hz
200 W Max
Nov 05, 2012 | Zenith XBR413 DVD Player/Recorder and VCR...
Lost the remote and the power button is broken (pushed in)
The part number is V2465500 Button case RXV595. This will fit the RX-V995. I ordered and replaced my own recently.
You can order it through Vance Baldwin, Herman's Electronics or Partsearch.com or Yamaha Parts Dept.
Cost is approx $10 plus shipping.
Note: The is one "hidden" screw retaining the button case that goes thru the circuit board for the front panel from inside the unit. You will need an offset phillips screwdriver to get to it. Be patient and good luck.
Apr 06, 2010 | Yamaha RX-V995 Receiver
Broken wire from wire housing to top control panel of AC Unit
bad stuff dude, you are going to pay about the same for the part as the unit, unless you learn to bypass that and put it on a light switch, black wire to fan and black wire to compressor on one side of the light switch on the other side the "hot" wire bringing power in, best of luck
Aug 10, 2009 | Heating & Cooling
Can not switch on home air condition with remote and no have manual switch
If you open the front panel of the indoor unit (it opens upwards) near the receiver there is a samll on/off push button (switch). If the indoor does run but still cannot be controlled by the remote, there is a reciever board problem. you need to call their servicemen.
May 28, 2009 | Cfm Daikin R410a Split System Air...
Remote
Hey gwilliams011,
If you'd like to order a replacement remote, you can generally do so by calling Best Buy Partsearch directly at 888-BEST-BUY (888-237-8289). You'll want to inform the operator that you're looking to order a replacement remote control, and they should be able to immediately place you in touch with our parts department. Otherwise, you can always visit our online partner site by clicking on the "Order Parts" link at the bottom of the page on www.Bestbuy.com.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 20, 2008 | Insignia LCDTV26 26 in. Television
Cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
Jun 14, 2008 | Jenn-Air JED8230 Electric Cooktop
Door on the Hoover washing machine, model H130E
make sure the tap is not broken off ,if the tap is good that means you switch is bad, replace it. hope this information could help you.
Apr 23, 2008 | Hoover H130E Front Load Washer
Remote Won't Work! Problem with TV remote receptor?
Try unplugging the set for 12 to 24 hours. if that does not work, theres a problem in the remote sensor circuit or the microprocessor circuit. its going to need a pro to fix it as it meeds trouble shooting.
Sep 05, 2006 | Toshiba 32AF41 32" TV
Televison & Video Logo
Top Televison & Video Experts
