Question about Cameras
Software for my allring 8x digicam - Cameras
I can't get my Memorex dvd writer to play a DVD, is there something I need to do to start it?
Search Results Memorex 98251 CD/DVD Writer 8x- External ..., Inc.
    Rating: 3.5 - ‎51 reviews Memorex 98251 CD/DVD Writer 8x- External: Electronics. ... my hp/xp has a writeable cd drive but a player dvd. wanted to save space on my hp ... hoops toget it to work, and I also feel cheated that I can't use the cd software that ...
    Customer Reviews: Memorex 98251 CD/DVD Writer 8x ..., Inc.Memorex 98251 CD/DVD Writer 8x- External ... See all 30 positive reviews> .... myhp/xp has a writeable cd drive but a player dvd. wanted to save space on my hp ... hoops to get it to work, and I also feel cheated that I can't use the cd software ...
Dec 29, 2015 | Memorex 32020019660 8X DVDRW External Slim...
Got a cyber-shot dsc p12 5.0 meagapixel cam,wont shoot mpeg,when set on the dial for movie capturing,only takes photo please help
try to reset digicam by pressing on-off button, if symptoms persist, set digicam to factory mode then try using again. if it doesn't done remedy the problem alreadt on proprietary software
Feb 18, 2011 | Sony Cyber-Shot DSC-P10 Digital Camera
Need software, lost my disc
May 08, 2009 | Cameras
Olympus stylus 790 sw digicam, lost software click on the link for software downloads and then click the link for free download of Olympus Master 2
Oct 24, 2008 | Olympus Stylus 790SW Digital Camera
Difference of two cube solution and formula
512x^6 -1/216 can be factored to (8x^2 - 1/6)^3
(8x^2 - 1/6)(8x^2 - 1/6) = 64x^4+ 1/36
(64x^4+ 1/36)(8x^2 - 1/6) = 512x^6 - 1/216
Hope this helps
Good luck Loringh
Oct 17, 2008 | SoftMath Algebrator - Algebra Homework...
Cant install
Most digicam installers are in CDs. Check your CD Rom drive if it is working. Install programs are usually started on Autorun files. If the Install program doesn't run automatically, explore the Installation CD and run setup from the installer. Follow step by step instruction until installation is completed. If the Installation CD is not working, try to look for the digital camera company's website in it's packaging and request for technical support.
There are also step by step instructions on installing your digicam and software found in the manual that came with your digicam unit.
Mar 29, 2008 | Cameras
Cannot write cds at lower speed like 8x
  1. Try to Use Nero or Easy CD creator software for better output.....
  2. Try burning Verbatim 16x DVD+R at 16x first and then burn another of the same type at 8x. And then compare the results. Most times, burning 16x-rated DVD+R/-R media at 12x or 8x will result in fewer PIEs/PIFs.
Whether 1x is better than 8x is another issue. Personally, I prefer 8x speed for most media I use these days (rated at between 4x to 16x but mostly 8x.)
Nov 26, 2007 | Computers & Internet
Transfer Images from Digicam to Thinkpad
Remove the camera software Then plug the camera in, and if it is a 2000 or XP Windows Scanner/Camera Wizard should sort it. The software supplied with camera are most ties more trouble than a help My advise is always leave the disk in the box and let Windoze do the work
Sep 04, 2007 | Canon PowerShot SD700 IS Digital ELPH /...
Cameras Logo
96 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
