Question about Sewing Machines
I am trying to learn about 3317 c sewing machine by singer. it says to push in the hand wheel. the handwheel will not move in or out. the needle does go up and down when the wheel is turned
  • Sewing Machines Master
  • 12,267 Answers
When you are "pushing in on the handwheel," what are you trying to accomplish?
Are you trying to wind a bobbin? If so, you need to push in on the "dimple" in the "center" knob of the handwheel. This disables the needle and prepares the bobbin winding mechanism. On page 6 of the manual, see #23 on the picture.
Singer 2502 User Manual Product View
Posted on May 03, 2017
    Habit-Forming:
    New Friend:
  • 39 Answers
Are you trying to get your machine to go backwards?
Posted on May 02, 2017
Have new never used singer simple 3232, tension was tight n I tried to use it n locked asap hand wheel/ pedal frozen needle wont move. no thread is apparently at fault. How do I proceed?
Return it if you can, I have seen these brand new with seized needle bars before. You can try putting a drop of oil on the needle bar where it goes through the supports and gently working the handwheel until you can get it moving.
Jan 04, 2017 | Singer 3232 Simple Sewing Machine
My sewing machine has stopped working, it was working ok , just a bit noisier than usual but now the needle wont move at all, even if i try to turn the wheel by hand
the machine may need oiling, check in your sewing machine manual to see about oiling it, it's also possible that the machine could have a damaged or broken part inside,,
Mar 17, 2016 | Singer Inspiration 4210 Mechanical Sewing...
Why does my hand wheel feel springy? why won't it turn and move the needle?
Is the bobbin winding mechanism activated? That will usually prevent the handwheel from turning and moving the needle. Otherwise, it could be broken...
Feb 23, 2016 | Bernina BERNETTE 65 Mechanical Sewing...
How do I add thread to the bobbin on Singer sewing machine 3114?
Your repair shop will have to fix the handwheel, but you can still wind your bobbin. UNTHREAD the machine completely, and take the needle out. Set up your thread to wind the bobbin, and push the winder over until it clicks. Wind your bobbin. I don't have a picture of your model; this is just standard.
Feb 23, 2015 | Singer Sewing Machines
It''s a SINGER sewing machine,,it's hand wheel run a slower and the next moment when i tried to sew a dress for me i found out dat it was'nt working well..i mean the hand wheel is stiff and not work but...
Has the clutch been disengaged to wind the bobbin? Pulling straight out on the handwheel on some machines will stop the needle from moving so that a bobbin can be attached and wound. If this is the case you simply push it straight back in. Also, on a computerized or electronic machine if the bobbin winding post is pushed right, the clutch will disengage. --Push it all the way left when you are done winding the bobbin to re-engage the clutch. If the problem is internal, like a slipped belt, you will need to have someone open up the machine to repair it. Hope you get it going again!
Apr 29, 2014 | Euro-Pro 9105 Computerized Sewing Machine
Have a singer 3221/3232 cannot disengage handwheel to fill bobbin what am I doing wrong
Are you sure you have to pull or push? It looks to me like you just slide the bobbin winder spindle to the right to engage.
Here's a manual for your machine... I'm sure more specific info is in there.
http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf
Nov 08, 2012 | Singer 2263 Mechanical Sewing Machine
HAND CRANK WON'T MOVE NEEDLE SEEMS TO HAVE LOST CONTACT WITH GEAR
adjustment info here. http://www.parts.singerco.com/IPinstManuals/15.pdf
And here is a manual for you. http://www.singerco.com/uploads/download/34_sm15.pdf
Those stop motion pieces must be put together correctly. Also make sure your needle is fully seated into the needle bar. Also look for any binding of metal parts. I had a 128 that came to me with a bent take up lever that would catch and make hand cranking difficult.
Good luck.. you'll love your old singer when you get it going well. Take your time and try not to get to frustrated.
One more thing... this blog is awesome if you are working on old singers.
http://vssmb.blogspot.com/search/label/fix%20%27em
Jul 27, 2012 | Singer Sewing Machines
Why is my singer SEWING MACHINE prelude HAND WHEEL RESISTING
Make sure the bobbin winder is in the position away from the bobbin stopper. When you fill a bobbin, you have to push the "spindle" towards the handwheel. If you do not push the "spindle" back into position (away from the handwheel), the wheel will remain locked.
Jul 18, 2012 | Singer 8280 Mechanical Sewing Machine
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
My needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Apr 07, 2009 | Singer 7436 - INGENUITY
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
