Question about Sewing Machines
Good evening. My Tajima TEHX-C embroidery machine give me a 3A6 error. I adjusted the Drive Start timing but it still gives me the error after a few embroideries
How do I fix the 3A6 error on a Tajima TEHX-C embroidery machine... Sometimes the knife cuts and sometimes it doesnt
akylas
  • 26 Answers
SOURCE: brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
dupina
  • 110 Answers
SOURCE: internal flopppy problem with Designer 1 embroidery machine
Dear bjdouce,
Push the floppy drive lid inwards and do the following:
First of all, check for any visible thread or dust inside the floppy drive.
Secondly clean the drive by blowing it with compressed air.
If this does not help, it is time to upgrade your machine to USB. Great to work with. Cost: plus minus $500.00.
Good Luck
Posted on Nov 17, 2008
SOURCE: Machine not sensing embroidery frame
Depending on your model of machine this problem is solved by replacing the hoop attachment unit on the hooping arm. (hoop sensor cable is not properly welded)
Posted on Jan 14, 2010
  • 470 Answers
SOURCE: how do I fix error code 2CF of Tajima embroidery machine for TFSN,TFKN,TFGN.
2CF - An immediate stop came in from an external. Check the external device or the connection to the external device.
device TMLG, connector joint 16 JH08
Check for a loose connection in any external device like a keyboard or card reader.
Posted on Feb 06, 2015
99rannellis
  • 8899 Answers
SOURCE: MY 18HDVGA TAJIMA EMROIDERY MACHINE GIVING ERROR 211 AND STOP ON EVERY THREAD BREKING SIGNLE&EVERY COLOR CHANGE.EVEN MANY TIME I REMOVE IT FROM ROD ON 100 POSITION BUT IT IS CONTINUE AFTER FEW SECOND
Search for:
Make Model error 211
or check the Troubleshooting section of your owner's manual
Posted on Apr 15, 2017
How do I fix error code 2CF of Tajima embroidery machine for TFSN,TFKN,TFGN.
Feb 06, 2015 | Sewing Machines
How to adjust trimmer on tajima tumx
WIll need more information about what you are trying to adjust?
Machine functions a mechanical cut, but the thread wasn't cut?
Cutter has timing to be set or replace the fixed blade. are two basic possibilities. I need to know what it's doing cut wise? to know what to adjust.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 19, 2014 | Sewing Machines
How do I fix error code BC1 on Tajima Embroidery Machine when there are designs on the flashdrive that did work yesterday
The format of your program may have different formats that will work for Brother but not Tajima. The extension of the program is the key to the one to use. You will notice a program name that is the very same but the extension is different. Your program can't be found if you use the wrong extension. Use other design extension or you may need to register the program.
Nov 18, 2014 | Sewing Machines
Hello, Error 225 Travel outside the set embroidery area
( When the software frame limit is set, or
on cap machines) Here is website for all the errors:
May 17, 2014 | Sewing Machines
Hi. I have a commercial one head tajima embroidery machine. I was sewing and realized I had no thread on one bobbin so I stopped the machine. Instead of continuing on, I decided to start all over with a...
Your new embroidery program has to be loaded first. The 2b7 is referring to needing instructions or in other words the embroidery program has to be loaded. Shut the machine down and turn the machine back on and load just as before.
Jul 06, 2017 | Sewing Machines
Tajima embroidery machine troubleshooting
We are having a similar problem with one of our single head Tajima TMEX-C1201 machines. In our case the design runs part of the way, then the head jumps and continues running and ruins the work. Any feedback on this would also be appreciated. Thanks.
Jul 15, 2013 | Sewing Machines
Tajima embroidery machine error code 316
it sounds like their is a problem with the electronics of the
embroidery machine and the machine needs to be checked.
Dec 19, 2012 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
