Question about Makita Drills
Makita cordless drill won't spin but can tighten chuck by hand
My Makita BHP451 won't spin...the torch light comes on when the trigger is pulled but the chuck doesn't spin....although I can still loosen and tighten the chuck by hand. Thanks
    Top Expert:
  • Makita Master
  • 78,257 Answers
Dead battery?
Posted on May 02, 2017
The battery is fine and the guide light comes on fine, but mt Makita BHP451 has no power to the motor. What's the problem?
switch it between forward and reverse a few times without pulling the trigger. then try again.
Nov 06, 2013 | Makita Drills
Changing the chuck of a 6408 makita electric drill
Open the chuck and remove the screw inside the chuck (if fitted) the screw is left hand thread, fit the short end of the largest hex key that will fit into the chuck and tighten the chuck, put the drill into low gear and turn the clutch to the drill position, support the drill on a bench and strike the long end of the hex key with a firm blow (right hand thread) it may be neccessary to strike it more than once
Jan 30, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
I have a makita BHP451 drill/driver with a keyless chuck and the gear box has striped out. I have a new gear box but do not know how to get the chuck off. I see a slot in the chuck that looks like you my...
The chuck has a left hand threaded screw inside. Turn to the right when removing the screw. Once the screw is removed you can remove the chuck by turning it to the left as it has standard, right hand threads. It is easiest to insert a large, L shaped allen wrench into the chuck, tighten the chuck, and hit the wrench with a hammer to spin the chuck off.
Jul 11, 2011 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
I can't get the drill bit out of My Makita 6333D cordless hand drill. I usually have no problem. I did tighten the chuck pretty tight, but now can't loosen it. Help.
put the drill in a vise and using a pair of channel lock pliers grip the chuck and it should come loose will a little tug on the pliers
Sep 12, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How to use hand drills?
Use of both is the same:
- loosen "chuck" (part where bit is installed).
- insert bit (hand tighen chuck so that bit is secured)
- tighten chuck securely with chuck tool, or by holding rotating chuck with hand and pulling trigger (GENTLY or you will shave off skin!)
- put drill in forward or reverse mode and pull trigger to inser or remove screw / drill hole.
ensure that battery is charged on cordless drilll.
squeeze connectors to remove and place in charger when battery is too low to operate drill.
Apr 27, 2010 | Bosch 14.4V Brute Tough Drill Kit
How do I change the bit in the Makita 6222D 9.6V cordless drill?
put the drill in reverse hold the chuck housing ( the black plastic piece around the bit) and squeeze the trigger. Hold it tight and it will pop loose, pull out the bit reinsert new one. Put the drill in forward squeeze the housing tigh and pull the trigger it will tighten right up.
Feb 26, 2010 | Saws
My chuck is broke , on my 18v makita cordless drill , how do i fix it
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
Sep 17, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Change the chuck on a makita DA39DA coredlesss right angle drill
look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger.
Aug 20, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita core drill model8406
Hi the 8406 was common for the intermediat gear to go have you yet stripped the gear box?
Quick test wear gloves to do this!
Turn on the drill if the chuck does not turn spin the chuck with a gloved hand TAKE CARE!! if the chuck catches grip one of the gears are gone.
Hope this helps let me know. Sean
Dec 22, 2007 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
127 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
