Question about Exercise & Fitness
The time on my fitbit charge 2 is wrong. How can I reset it?
    Top Expert:
  • 80,637 Answers
You must hook it up to the computer and sync it from that.
Posted on May 02, 2017
How do I change time on my Fitbit
  1. Log in to your fitbit.com dashboard and click the gear icon in the top right corner.
  2. Click Settings.
  3. Scroll to the bottom of the Personal Info page and modify your timezone.
  4. After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.
How do I reset time and date? - Page 2 - Fitbit Community
https://community.fitbit.com/t5/Charge-HR/How-do-I-reset-time-and-date/td-p/.../2
May 05, 2018 | Exercise & Fitness
How do you set the time on the Fitbit charge
Help article: How do I change the time on my Fitbit device?
https://help.fitbit.com/articles/en_US/Help_article/1176
  1. Cached
  2. Similar
Jump to How do I fix the time on my Fitbit Blaze or Fitbit Charge HR? - To change your clock to a 12 or 24 hour clock: Log into your fitbit.com dashboard and click the gear icon. Choose Settings > Personal Info. Under Advanced Settings, find Clock Display Time and select whether you want the time shown in 12-hour or 24-hour clock units. Click Submit and sync your device.
https://community.fitbit.com/t5/Charge-HR/How-do-I-reset-time-and-date/td.../2
  1. Cached
Log in to your fitbit.com dashboard and click the gear icon in the top right corner. Click Settings. Scroll to the bottom of the Personal Info page and modify your timezone. After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.
Solved: How to set time on Charge - Fitbit Community
https://community.fitbit.com/t5/Charge/How-to-set-time-on-Charge/td-p/759901
  1. Cached
  2. Similar
Dec 9, 2015 - 20 posts Solved: I am trying to setup my new Fitbit Charge and downloaded the manual, but it says no where how to set the clock. Also after setting up on line. Update to Set Time Manually 2 posts 5 Apr 2017 How to change the time on my Fitbit Charge 2 20 posts 6 Mar 2017 Solved: How do I change the time on my Fitbit? 18 posts 21 Dec 2015 How to reset clock? 20 posts 15 Nov 2015 More results from community.fitbit.com
Apr 13, 2018 | Exercise & Fitness
Changing the time and date on my Fitbit Charge 2
  2. Click Settings.
Apr 04, 2018 | Exercise & Fitness
How to set the time on fitbit
  2. Click Settings.
Mar 10, 2018 | Exercise & Fitness
My fitbit 2 charge is showing wrong time and date.how do I reset it
completely shut down the phone/device you sync with and the Fitbit. When re-starting, make sure there are no other devices that are trying to connect to the Fitbit, and that the app on the device you're syncing with is up to date.
this usually works. If not - contact Fitbit Customer Support.
Jan 09, 2018 | Exercise & Fitness
How do I reset the time on my Alta fitbit?
Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order.
1. Re-sync your Fitbit to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
Hopefully one of those steps will get you on the right time, but if not, try resetting your Alta by doing the following:
Plug in your Alta in a USB (computer, or adapter) as you normally would to charge it. It should begin charging.
Press the button on your charging cable three times within eight seconds, briefly pausing between presses. (The button is on the end of the charging cable).
Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
After you see the logo you can unplug your tracker from the charging cable.
Hopefully one of those things will get you on the correct time :)
Oct 20, 2017 | Exercise & Fitness
How do I reset the time on my Fitbit watch
Here is the way you can reset time on your Fitbit without Reset Fitbit Charge HR -
  • Open the Fitbit app on your phone
  • Then Go to the Advanced Settings
  • Now turn off automatic Time Zone
  • Press Select Time Zone
  • Choose the time zone according to your country
  • Synchronize your Fitbit to your smartphone
The Guide Of Reset Fitbit Charge HR Complete Guide
Aug 08, 2017 | Exercise & Fitness
Can the screen cover on a A Fitbit HR Charge be replaced
It can!
(6-Pack) EZGuardZ Screen Protector for FitBit Charge HR (Ultra Clear ...
https://www.amazon.ca/6-Pack-EZGuardZ-Screen-Protector-FitBit/dp/B00SVW2DPO
  1. Cached
Pack of 6 Brand New EZGuardZ™ Screen Protectors; Precision Cut for your FitBit Charge HR, NO Cutting Necessary; No worrying about sticky residue; Thin, ...
Screen Protector And How To Get Scratches Out - Fitbit Community
https://community.fitbit.com/t5/Charge-HR/Screen-Protector-And-How.../835469
  1. Cached
Jun 21, 2015 - If you have a Fitbit Charge HR, I highly recommend getting a screen protector. The plastic screen is not strong at all, and it is also very easy to.
Best screen protector brand for Charge 2. - Fitbit Community
https://community.fitbit.com/t5/Charge-2/Best-screen-protector...Charge.../1543173
  1. Cached
Sep 2, 2016 - Wendy ' California. Retired Classic, Ultra, Charge,Charge HR. In use One, Charge 2, Surge, Blaze, Alta and Aria ' Windows 10 ' Android Moto ...
Amazon.com: XtremeGuard™ Screen Protector for FitBit Charge HR ...
https://www.amazon.com/XtremeGuardTM-Screen-Protector-FitBit-Charge/.../B00SV...
  1. Cached
Buy XtremeGuardTM Screen Protector for FitBit Charge HR (Ultra Clear): Screen Protectors - Amazon.com ? FREE DELIVERY possible on eligible purchases.
FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen ...
https://www.amazon.com/INVISIBLE-Protector-included-Protection.../B00UMAXNJS
  1. Cached
Buy FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen Protector (Front Shield included) Military Grade Protection Exclusive to ACE CASE: Screen ... screen cover on Fitbit HR Charge Google Search
Nov 16, 2016 | Exercise & Fitness
Exercise & Fitness Logo
167 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
