Question about Philips Televison & Video
Connect pc to philips tv via HDMI without "source" function
I have a philips tv with HDMI connection, but the remote control has no 'source' button to switch from TV to HDMI input. Is there a way to...? Thanks
  • 111 Answers
Posted on May 02, 2017
    Top Expert:
  • Philips Master
  • 12,962 Answers
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
How to connect viera link
What is Viera Link? Viera Link allows the control of other Panasonic home AV devices via the television remote control.
By pressing the Viera Link button on the television remote, it is possible to turn on and navigate the menus of other Viera Link equipment. Please note, Viera Link requires an HDMI connection between the television and the external source.
More control functions have been added with each new generation of Viera Link compatible products. However, it is important to note that the newer functions only work if both products are from the same year of manufacture. Therefore, if an older source is used with a newer year of television, only the older functions common to both years will work.
Aug 26, 2014 | Panasonic Viera TH-42PX80U Plasma TV
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Isn't this just a simple hookup? What am I not doing?
You either need to change the input source. Currently the source is TV, depending on how you connected the DVD player to the TV, it should be composite (A/V), component video or HDMI. (S-video is also a possibility. Very few DVD players are connected on the RF (coax) input which might be channel 3 or 4 without having a converter between the DVD player and the TV.)
Look on your TV remote for a button marked Source or Input. You may also find this button on the TV. (On some TVs, this may also be accessed through the menus.)
How did you connect the TV and the DVD player? If your audio and video were connected via three RCA plugs (yellow, red, white) on each end, then use the composite video input. If you used cables with 3 RCA plugs for video (yellow, green, blue) and 2 for audio (red/white), then switch to the component input. If you used HDMI which carries audio and video in one cable (with rectangular ends), then use the HDMI input.
Some older TVs only have the Source/Input button on their original remote. Not all universal replacement remotes have this button, you may need a different remote. Those that do may require you to try additional codes for your TV manufacturer to enable the button. (The on./off buttons often will work with more of the codes for a brand.) The ones that can be programmed via a USB connection to a computer are most likely to support the function. Please add a comment with the type of TV for additional help with this.
I hope this helps.
Apr 21, 2012 | Sony Dvp-sr500h 1080p Upscaling Dvd Player
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Nov 26, 2011 | Philips Audio Players & Recorders
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Trouble trying to connect my dvd player and set it up to my new 42 " L cd lost instructions!
You will need to determine if your DVD player is HDMI or Scart. If you connect it via a scart lead, then it should automatically turn on when you power it up, if not it will be located on your tv under the appropriate source/input label, ie AV1/AV2, or SCART.
If you are using a HDMI lead, then you will have to turn it over yourself, as HDMI does not support switching control. To do this, locate the input button on your remote (sometimes labled source) and press it until you can select the correct HDMI input using either the directional buttons, or by repeatedly pressing the input button.
Hope this helps
Jan 03, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
Mar 27, 2010 | Philips 32PF5531D 32 in. LCD Television
Problem with tv sender
Hi,i learned on another forum that if you connect an hdmi cable apparently it disables the functions of the scart sockets,especially where the remote control is concerned.This is something to do with virgin media's setup and not any equipment fault.If you want to go back to two room viewing try unplugging the hdmi lead.
Jun 22, 2009 | Philips Televison & Video
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Apr 29, 2017 | Vizio Televison & Video
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
