Would like a vidio on how to replace ege valve
  • yadayada
    yadayada May 02, 2017
    What is an "ege" valve.
    Habit-Forming:
    New Friend:
  • 39 Answers
Go to You Tube and type your question, it will take you to several video's on how to.
Posted on May 02, 2017
How to replace de egr valve pipe toyota camry LE 1998 4 clynd
Hi,there is a good vidio on utube that will show you how to do the job.hope this was some help hope you sort it.
Sep 20, 2017 | Toyota Cars & Trucks
Thinkpad ege 0578 pcy
Remove battery from laptop model no battery is normally found on inside section of battery ,alternatively look up battery for thinkpad ege 0578 pcy in google or ebay
Jul 29, 2014 | Battery Biz Computers & Internet
1997 ford f-150 4.2L cranks but wont start
Did you check the Inertia sensor? This will cut the fuelpump power and the reset is on the part which should be around the floor kickpanels. Recheck your fuel pressure and see if it has changed from earlier when it ran.
The crankshaft position sensor has a variable voltage which should be at a minimum of .1 Volt. It sends the signal to regulate injector firing and crank position. Perhaps resistance on #3 and #4 injector wiring is different due to corrosion; you could OHM test.
As for starting issue, you made some parts changes on the coil connection, maybe check to see if you dropped the power feed to the coil.
Apr 03, 2014 | 2005 Ford F-150 SuperCab
1995 Toyota Tercel code p0409
if you manually push up on the EGR valve and the engine doesn't stall and the passages are all cleaned out then the problem is the EGR valve.
Aug 18, 2017 | 1995 Toyota Tercel
Why is my car shakeing and smells like rotten eges
You have an engine misfire I bet. Have a shop put it on a scanner to see what is causing it.
Jul 27, 2012 | 2004 Kia Spectra
I have a 2003 Santa Fe (approx 71K miles - new brakes in March 2007) that has been making a low pitch sort of squeal when I am accelerating between 15 mph to 40 mph. Getting more frequent and sometimes at...
Either the caliper pins are not releasing properly(cleaning and lub. will solve that) thus causing brake pads to partially stay in contact with your brake disc(rotor)
or its possible that your brake discs have exessive riges on the outer ege(if spec. allows discs can be skimmed or replaced)
also try shamferring the brake pad eges and remove forreign dust/dirt particles from and arround your calipers.
Jul 23, 2008 | Hyundai Santa Fe Cars & Trucks
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
