Question about Ovens
F&P OS302 was in self cleaning when we had a power failure. The oven will not heat but controls, fans operate. Control board or thermostat is bad?
    Top Expert:
  • Ovens Master
  • 12,962 Answers
If your heating elements are not open then the issue lies with the controls and circuitry that operate the heating coils. Get yourself a schematic and trace it out and you will find the culprit.
Posted on May 02, 2017
We have a Kitchen Aid KEBC147VBL03 wall oven. When we ran the self clean oven (big mistake), the oven shut off and locked. There is no display/lights on the control panel. And, the door is stuck in lo
Does the control board or anywhere of control panel have a fuse? If not beter have it service. Expect a quotation from the serv. Tech after it found how big or expensive theparts tobe replace to make ur unit operational agian
Sep 22, 2014 | Ovens
My Fisher and Paykel Aerotech OS302 oven will not heat up to desired temperature.
This type of problem normally can be ascribed to a defective thermostat. Unfortunately there is no test for a thermostat, it has to be replaced to see if the problem has been sorted out.
One thing you can do is remove the thermostat bulb from the oven and place place it in a position where it will not heat up. Place an oven thermometer in the oven. Switch on and see of the temperature climbs above what you wee seeing before. This is a very much hands on test as you have no control over the temperature that the elements can get to. As soon as you see the temperature reach a point above that seen before, shut down immediately.
Feb 06, 2011 | Fisher and Paykel AeroTech OS302 Electric...
I used the Self Cleaning feature on my Fisher & Paykel OS302 wall oven for the first time, and now the oven will not heat. The lights and fan run, but no heat.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 23, 2010 | Fisher and Paykel AeroTech OS302 Electric...
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
Oven wont heat
That depends if the oven is electric or gas.
If it is electric, it can be heating element, temp probe, or control knob/buttons, board and wiring.
If it is gas it can be the igniter (check spark) , the thermostat, the safety valve that prevents accidental gas flow, or the control.
If the oven has self cleaning cycle, check that it is not stuck on self cleaning, try unplugging for a while and restarting self cleaning cycle in that case.
Check also What is wrong with your Range/Stove/Oven?
Mar 29, 2009 | Ovens
Whirlpool oven will not heat up after self lean
Check the overload thermostat inside the back panel of the oven.
No continuity? Replace it.
Mar 02, 2009 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
