Question about Garden
What is causing my pressure washer engine to stop hard/suddenly?
It's a Kohler Courage XT-7 engine. I replaced a leaking oil pan gasket and torqued the bolts back in place. Filled it with 10w30 synthetic. I've checked the fuel line and the carburetor, which appear to be clean. Spark plug looks normal and is gapped correctly. I've replaced the water pump with a brand new one. When attached, the engine would start up but then quit when trying to build pressure. Seems to run longer from a cold start. I then removed the pump to see how the engine runs without a pump attached. Within a minute of running normally, it stopped HARD with a clunk. That can't be good and I have no idea what would cause it stop so suddenly. Is there internal damage to the engine?
    Habit-Forming:
  • 100 Answers
Your engine is experiencing a heat seizure... the piston sticking in the cylinder as it expands under heat with poor lubrication.
Posted on May 02, 2017
Testimonial: "That sounds possible, however the engine specification is for Class SJ or higher 10w-30. I changed the oil and used 10w-30 Service Class SN synthetic oil, which is better than SJ. It's also filled to the correct level. Also, If I manually turn the crank when the engine is cold, nothing seems amiss. Could the rings be worn/damaged?"
    Top Expert:
  • Garden Master
  • 12,962 Answers
Sounds like you have a real sick puppy on your hands since it will not even work properly with no load. Sure the carb is giving the engine enough gas?
Testimonial: "Drained the gas tank the other day, and checked the carb for deposits - It's clean and clear. Poor fuel flow wouldn't cause the motor to seize like it did today, though."
  • 1 more comment
  • richie46 May 03, 2017
    When the engine "seized" were you able to turn it over? Remove plug and then try while still hot? I am as confused as you are about the clunk. Before they seize they run for sh-- and then just stop.
  • Nick Termini
    Nick Termini May 03, 2017
    I had been able to turn it over before while warm/hotish the other day, but after today's "clunk" I didn't want to start it again. It has an ignition switch so with it in the off position I can pull the start cord and feel the motor parts moving smoothly.
    So then it can't be seized since that is sort of a permanent thing. If you cannot spin the engine manually after it is hot and unexpectedly shuts down, then it has to be some sort of thermal/expansion issue. Are lubrication channels clear and functional?
Husky 2600 psi with Kohler Courage x7 173cc engine. Why does it leak gasoline?
Bad gas line, loose gas line clamp, cracked gas tank. Defective bowl to carb gasket.
Mar 26, 2016 | Garden
I have a kohler courage xt-7 on a white push mower, oil is spiting out of the crank vent tube. Whats the fix ?
You need determine the cause of the problem first.
Is the crankcase oil overfilled? If so is it laiden with fuel? If so then you have fuel leak.
If the crankcase isn't overfilled is it cause by blow by pressure from a bad head gasket or cylinder wear?
Jan 14, 2015 | Garden
Oil pan bolt torque
oil pan bolts are torqued in inch lbs due to their size and usually doesn't require a specific torque value. all bolts in a manual does show torque settings in all applications.However because of its non critical application a specific value is not necessary. a "snug" tightness is adequate with proper gasket/sealer in place to prevent seepage or leaks. in that area of the engine,leak can come from almost anywhere. top,front,or even rear of the engine blown by the wind a car creates while in motion. oil sensors{ but not limited to} are notorious for leaks as the vehicle ages particularly in that area. steam clean or thoroughly degrease the area and run the engine a few miles and recheck the area before proceeding to make repairs.
May 27, 2014 | 2001 Nissan Pathfinder
Gas leaking from carb when not in use.how to fix.
clean the float needle and check its not ridged where it seats ! if so replace !
May 27, 2014 | Kohler NET HP COURAGE XT-7 SERIES VERTICAL...
Wont spray
I hope the engine wont spray... if it's a pressure washer thats not spraying the name of the unit would help... but does it build pressure but doesn't spray - check the wand
does it even build pressure ??? no - replace pump
Oct 18, 2013 | Kohler NET HP COURAGE XT-7 SERIES VERTICAL...
How do you replace an oil pan gasket on a 1991 buick skylark custom
remove the oil pan,clean off the old gasket with a scraper,clean off all of the old gasket from the oil pan and the engine,mild solvent works pretty good.using gasket adhesive put nice even beed all around the edge of the oil pan,place the new gasket on top of the beed of adhesive,place the oil pan back against the engine replacing the bolts from the oil pan,tighten the oil pan bolts back to torque specs. of the manufacture.
Dec 24, 2012 | Buick Vehicle Parts & Accessories
When changing the oil pan on a 2006 town & country do you have tighten the bolts in a sequence?
Removal & Installation
2.4L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the engine oil.
  3. Remove or disconnect the following:
    Negative battery cable Structural collar A/C compressor bracket to oil pan bolt Oil pan
  4. Clean the oil pan and all gasket mating surfaces.
To install:
  1. Install or connect the following:
    Oil pan gasket to the block after applying engine RTV at the oil pump parting line Oil pan. Torque the bolts to 105 inch lbs. (12 Nm). Structural collar Negative battery cable
  2. Fill the crankcase to the correct level.
  3. Start the engine, check for leaks and repair if necessary.
To install:
3.0L Engine
    Negative battery cable Starter motor Front motor mount bracket Bending braces Torque converter dust shield Oil pan
    Fig. Oil pan mounting bolt tightening sequence-3.0L engine
To install:
  1. Clean the oil pan all mating surfaces.
  2. Apply RTV gasket material to the oil pan.
  3. Install or connect the following:
    Oil pan. Tighten the bolts in sequence to 50 inch lbs. (6 Nm). Torque converter dust shield Bending braces Front motor mount bracket Starter motor Negative battery cable
  4. Fill the crankcase to the correct level.
  5. Start the engine, check for leaks and repair if necessary.
3.3L & 3.8L Engines
    Negative battery cable Engine oil dipstick Drive belt splash shield Strut to transaxle attaching bolt and loosen the strut to engine attaching bolts Transaxle case cover Oil pan fasteners Oil pan and gasket
To install:
  1. Clean the oil pan and all mating surfaces.
  2. Apply a 1 / 8 inch bead of gasket material at the parting line of the chain case cover and the real seal retainer.
    New gasket on the oil pan Oil pan. Torque the bolts to 105 inch lbs. (12 Nm). Transaxle case cover All bending brace bolts Drive belt splash shield Engine oil dipstick Negative battery cable
To install:
May 05, 2012 | 2006 Chrysler Town & Country
Sudden oil pressure drop to 20 lbs. oil is brown and hot
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Mar 03, 2012 | 1996 Chevrolet S-10 Pickup
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
