Is there a owners manual for a EBBTIDE Boat, Serial number 41255 HULL # ETC41255M84F Thank you
Eiter one I can download or just read and print on parts I need.
  • 28 Answers
When all else fails, do a search for what you need, online. I found this url for the Ebbtide boats website:
Posted on May 03, 2017
  • 409 Answers
SOURCE: free owners manual
hi there,
go to
then scroll down to the bottom right and you'll see customer support and then manuals & literature.
click on that and then type in your model #.
all the manuals are in .pdf, so make sure that you have Acrobat Reader.
Posted on Sep 14, 2008
  • 8596 Answers
SOURCE: I am in need of an owner's manual for a SERIAL #: D34692693A
Here si the manual:
-Tha Mp3 Doctor
Posted on Mar 20, 2009
  • 410 Answers
SOURCE: Radio need codes to operate
Check in the glove compartment or on the arms of the trunk.  You should be looking for a 5 digit number.
Posted on May 25, 2009
  • 86 Answers
SOURCE: I need year of starcraft boat
If you find the hull identification number which is always stamped on the right side of the transom then the last two numbers indicate a year. Ex. BUJ5C45208 Would be a 2008.
Posted on Aug 09, 2009
SOURCE: Looking for a ''FREE'' owners manual download Kenmore 385 17124
kenmore 158.132.01 manual
Posted on Aug 12, 2009
Looking for which boat motor modle number of block used buy the hull number will that tell me anything
The manufacturer of the boat should be capable to give you the make/type/power/serial information if you give them model and serial of the hull.
At least if it wasn't changed during the lifetime of the boat.
Aug 08, 2017 | Boating
What is the maximum horsepower for a Tuffy Tri-hull serial # TUF41017M76F?
Your boat is required to have a USCG plate .. it states the max. HP and the number of people/weight allowed..
If it doesn't, contact the mfg.
Jul 16, 2017 | Boating
What can i do to stop the flashing of the depth finder at times it will not show the current depth
Hey Joe,
Wow.. where to start.. there are so many things that will cause the issue you are describing.What type of electronics do you have? Does this happen at all speeds? Where is the transducer mounted? I need more info about when it stops reading.
1.Wrong setting on the unit
2 Bad transducer
3 Bad transducer mounting (either inside the hull or outside the hull.)
4. (In hull) Turbulence going under the boat (mine quits reading at about 55 mph @ half trim...the boat is lifting so much it causes air pockets so the transducer loses contact with the water)
5. (Outside hull) Turbulence around the bottom of the boat where the transducer meets the water.
Good luck,, when you get the info.. reply to me..
Jun 03, 2017 | Boating
Got no serial or id plate ,got number off freeze plug need to get new serial plate
Hi David:
Seems unusual to me that a boat (hull) ID number would be on something removable like a freeze plug.
Usually the serial number builder, weight, and load information is on the plate that you mention. It should be attached to a bulkhead or the transom, either inside or out.
Registration is typically handled by the Coast Guard or Gov't depending on where you are. Since they love to collect sales taxes, they also keep records, so if you can ID the boat by REGISTRATION NUMBER, they should be able to readily come up with the serial number.
If the boat was sold to you with all possible means of ID removed, I would personally be quite suspicious. Hope you know and trust the seller and can produce the Bill of Sale and proof of ownership.
I'm wishing you luck.
A visit to the nearest authority in your area, even the police, will get you started on resolving this.
Feb 28, 2016 | Boating
How can I find model and year of my boat having only a serial number from the hull?
You can't,what type of boat is it,what make what length
Oct 01, 2014 | Boating
Where is serial number
The serial number on the boat is located on the back (transom) right hand side near where the hull meets the deck. On the outboard motor it's on the bracket that attaches the motor to the transom and usually on the engine block as well.
May 21, 2013 | Nitro Boating
Transducer is throwing up a large Rooster tail.I installed it to instructions
Might help to tell us what kind of boat - deep V hull 22 ft.? bass boat with shallow V hull? Some need the transducer closer to the centerline of the vessel while others do better more outboard, Naturally they need to be flush with the hull no matter where they are located. Depending on the transducer, you could also try properly mounting it inside the vessel near the transom. Good new is you are getting good info from it. Cheers Pete
Nov 16, 2017 | Humminbird 586c
I have a new unit to fit. Can the transducer be mounted inside the hull? It currently gives me strange readings whether inside or out but we are on dry land - if that makes a difference
there are two kinds or transducers out there on the market --- some that can be mounted inside the hull and others that need to be mounted on the outside of the hull, the instruction manual should indicate which transducer you have. AND YES the transducer will only work when you are on the water --- the readings on land are no good and it will not work. install it on the boat and then test the unit on the water. BUT if you do want to test the unit before you install it to the boat you can always take the boat out to a lake ( or wherever ' on the water ' ) and mount the transducer to a long dowel or stick and hang it over the edge of the boat and this will work fine for testing.
' fish on and have fun '
Dec 31, 2010 | Eagle Cuda 242 Fishfinder
Jul 09, 2009 | Boating
63 people viewed this question
