Question about AGA Kitchen Ranges
I've got an Aga 6 4 that I need moving to a new property Ne270ut to td113ry is anybody able to help ?
2words 1 6 letter word and 3 letter word gaairlbea
Take your pick:
aba glaire
abelia gar
abelia rag
aerial gab
aga bailer
aga librae
airbag ale
airbag lea
ale airbag
baa glaire
bag aerial
bag realia
bailer aga
gab aerial
gab realia
gar abelia
gie labara
glaire aba
glaire baa
labara gie
lea airbag
librae aga
rag abelia
realia bag
realia gab
Jan 27, 2016 | Computers & Internet
Call me silly but whot is the high setting on my oil aga 1 or 6
The highest/hottest setting on an oil aga is usually 6, however if it's not hot enough it's possibly because it has a restriction in the base. If this is the case it will need to be cleaned out, which would normally be done by a service engineer every six months.
Jun 17, 2014 | AGA Kitchen Ranges
Hi all i have a AGA MASTERCHEF Model 100 DF Serial number D0000124 and cant find LPG coversion Kit AGA says no kit can anyone help please Mal
Hi I have the same problem - mine is LPG and I need to convert it to NG... if anyone has any solutions I would be really grateful.
Thanks - Juliz
Feb 03, 2013 | Kitchen Ranges
I've Cannon 1100D and I bought Cannon RC-6 remote controller and I didn't know how to connect it with my 1100D. Can anybody help me ?
Hi! Unfortunately,the remote controler RC-6 isn't compatible to your 1100D. Because this Canon model doesn't come with the options for remote control, but you can use the Rs-60e3 wich is a cable remote.
Hope it helped!
Sep 03, 2011 | Canon RC6 Wireless Remote RC 6
AGA ERROR IN TALLY 2265
either your aga motor is bad or your board set is bad. Turn unit on watch the printhead while opening the cover. The printhead should move back and display "cover open". When you close cover the printhead should move closer to paper. If not bad aga motor or bad board set.
Dec 15, 2010 | Tally Dot Matrix T2265C Printer
Model T2280. How can I correct AGA error?
This is normally caused by a bag AGA sensor.
TALLYGEN 447540 AGA ASSY T2265 New
Link lists a T2265, but the sensor is the same.
Jun 08, 2009 | Tally Office Equipment & Supplies
I don't know how to tell the amp ratings of these fuses
Electronic - PC Board and Small Dimension Fuses - PC Board & Small Dimension Fuses 1/4” Dia. x 5/8” to 1” length ferrule fuses
AGA Specifications Decription: Fast-acting fuse. Dimensions: 1/4· x 5/8· (6.4 x 15.9mm). Construction: Glass tube. Ratings:Volts- 125Vac (or less)
Amps- 1/16-30A
IR- 10,000 (1/16-11/2A @ 125Vac)
- 200A (2-5A @ 125Vac)
- 1000A (6-30A @ 32Vac)
Agency Information: CE, Std. 248-14, UL File E19180, UL Listed, Guide JDYX 0-11/2A UL Recognized, Guide JDYX2 2-12A. Features and Benefits: · Fast-acting for maximum protection.
· Size rejects insertion of other fuse types. Typical Applications: · Electronic Circuits Catalog Number Amps AGA-1/16 1/16 AGA-1/10 1/10 AGA-1/8 1/8 AGA-1/4 1/4 AGA-3/8 3/8 AGA-1/2 1/2 AGA-6/10 6/10 AGA-3/4 3/4 AGA-1 1 AGA-1 1/2 1 1/2 AGA-2 2 AGA-2 1/2 2 1/2 AGA-3 3 AGA-5 5 AGA-6 6 AGA-7 7 AGA-7 1/2 7 1/2 AGA-10 10 AGA-15 15 AGA-20 20 AGA-25 25 AGA-30 30
Apr 11, 2009 | Electrical Supplies
I keep getting Microsoft Wizard notifications about finding new hardware and needing to seek compatible drivers--e.g. AGA video, etc.
it means that there is hardware that windows is recognizing which you have no drivers for....go to my computer/right click then properties/then hardware/then device manager/ everything should have a + sign...if not you will see a yellow sign which will tell you what hardware drivers you need
Aug 27, 2008 | ASUS Computers & Internet
Need to dismantle an AGA. where to start after switching the gas off?
try this site for how to e books dismantle move and reassemble your aga
http://www.ebooks-on-howto.com/
Aug 21, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Paul Carew
Tom Chichester
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
