Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
Cordless drill- chuck jammed.Model No. HP146F2B
    Sergeant:
  • 281 Answers
You can use 6 inch pipe wrench on the top of the chuck and an eight inch on the large part of the chuck.Put a rag in the pipe wrench jaws.Lay the drill on a flat surface with the chuck pointed at you.The handles face the same way,small one on the bottom to lock the chuck and the 8 inch on top so they look like scissors. Depending on which way the chuck is jammed will determine if the handles are on the left or right side.Gloves and safety glasses will make holding the top wrench with a bit of force to lock every thing in place.Now just a tap on the end of the eight inch wrench will loosen the chuck.If the set up is wrong you will only jam the chuck more.
Posted on Feb 04, 2012
    President:
  • 583 Answers
B&d usualy thow away inthis range.still you can remove the chuck and fix or relace chuck unscrews anticlockwise hold shaft behind chuck with thin spanner or it may be the type with allen screw dwn the centre of chuck
Posted on Jul 25, 2009
  • kerry littleton Jul 25, 2009
    b&d usualy thow away inthis range.still you can remove the chuck and fix or relace chuck unscrews anticlockwise hold shaft behind chuck with thin spanner or it may be the type with allen screw dwn the centre of chuck
12 volt black and decker keyless chuck will not close. Model CD120G
Try giving the inside a spray with WD40 then try closing the chuck. Check that there is not a left handed screw in the center of the chuck that has become partialy unscrewed. The chuck can jam open and just need a strong gril to release it. If the outer sleve of the chuck is turning but nothiing happens then you will need to get the chuck replaced.
Jun 10, 2012 | Black & Decker 18V Cordless Drill/Driver
The collet seems jammed and I cannot adjust...
This is just a longshot, but look down inside the chuck with a flashlight and see if your chuck-mounting screw has migrated out. I had the same problem with my Milwaukee, and turns out that's what it was. The collet was jamming up on the chuck screw.
May 02, 2011 | Black & Decker & Cordless Drill
How to remove the chuck on a makita or other hand held electric cordless drill
usually with a special tool to hole the drive, if you look at the back, if the chuck, where the shaft mates you will see it has two flats or a profile on it, you make get a tool that can grip that and twist the chuck. If it hasn't you have to somehow jam the Motor, or the shaft, and again twist.
Mar 25, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
How to take my chuck off broke tool off inside chuck
The screw that holds the chuck on, is in the bottom of the chuck itself. If there is something jammed in the chuck, it must be removed in another manor. If the chuck is jammed, I have used two pair of channellocks to open the it.
Oct 07, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Chuck is locked in open position
What you can try is some WD 40 spray into the chuck and then find a GOOD pair of gloves or a rag and hold the collar of the chuck either by hand or use the rag and a pair of channel locks to protect it and then use the tool motor slowly and see if that doesn't release it
May 25, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
NUTOOL CORDLESS DRILL
spray the chuck with wd40 and chap it with a hammer or off a solid wall
Jan 18, 2009 | Dynamic Drill Doctor Large Chuck, Black,...
Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Aug 18, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
575 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
