A/C stopped working. The compressor is working but no blowing out of heat or air.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
Cooling fan or thermostat
Posted on May 02, 2017
    New Friend:
  • 51 Answers
You don't say is this a window unit or a central air ? Just from what you have posted it sounds like the fan motor is shot.
Fan that blows heat an air stopped working on my 2004 envoy. Should I check fuses first?
Do you know what fuse to check ? Can you add a little more info ?
air stopped working ???? Air conditioning ? Does the compressor clutch click on , engage etc....
Apr 22, 2017 | Cars & Trucks
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
MSZ-A26YV only blows air now, (no heating or cooling), no error indication. Worked all fine one day then few days later stopped. Emergency switch does the same. Looks like the external unit fails to pump...
try to check your compressor if working if not check electrical parts like capacitor. overload if defect replace. also try if compressor working observe the condensing unit fan blowing hot air if not theres possibilities of leakage of refrigerant gas need for braze leak then recharge refigerant gas. or possible compressor loose compression need for replacement.
Feb 12, 2011 | Mitsubishi Heating & Cooling
Compressor ?
Sounds like you are over heating the compressor, try cleaning the out door unit coil. Take a hose and blow water through it, be carefull not to bend the fins.
Jul 17, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 22, 2010 | LG Heat cool Window Air Conditioner
The AC stops blowing air for a while and then re-start working normaly.
Have you noticed that the AC quits blowing cold air when you are heavy on the throttle, or climbing a hill? Does it return to blowing cold air when you let back off the throttle and relieve the load from the engine?
If you answered YES to those questions, your AC is operating normally. AC compressors take quite a bit of power from the engine to operate. In vehicles with smaller engines, the AC compressor will disengage when there is a heavy demand for power placed on the engine, and you will not get cold air. When that demand is gone, it re-engages power to the AC compressor.
Dec 03, 2009 | 2006 Mazda 3
No heat or air are blowing from the front , back is fine
it sounds like your fan motor may be stuck or has gone out
Feb 04, 2009 | 1999 Ford Expedition
My Carrier 58dxc is making a loud noise
If your turning on heat and the unit is knocking and blowing cold air, your compressor is having problems in heat mode, could be reversing valve. A tech is needed in your situation. Getting the prob fixed right away will save you dollars..
Dec 02, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
