Question about Poulan Garden
Poulan chain saw, primer bulb hose to carb, does it have a nipple in the tank to connect to?
    Master:
  • Poulan Master
  • 645 Answers
The fuel line should connect to the fuel filter in the tank.
Posted on Dec 04, 2017
5 Suggested Answers
  • 4088 Answers
SOURCE: Poulan 2150 gas chain saw. How do I connect new
Make sure the tank is filled with fresh fuel mix.Try hooking the line that goes to the tank to one of the two primer ports and operate the bulb. If it does not pull fuel in, reverse the connection to the primer and try the bulb again. Once you get fuel into the bulb, move the tank line to the other port. Install a line from the open port on the primer to the open port on the carburetor. Try the primer bulb again, it should pull new fuel from the carburetor if the two connections at the carburetor have not been reversed. This is a kind of 'hit or miss' business when connecting fuel lines that involve the primer bulb. Nothing seems to be marked on the involved parts. Hope this helps
Posted on May 15, 2010
SOURCE: I need the routing of the gas lines on a poulan
how to route the gas tank lines in a poulan chain saw
Posted on Nov 18, 2010
  • 2239 Answers
SOURCE: Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Posted on Jun 24, 2011
  • 19 Answers
SOURCE: My Poulan 2025 Chainsaw fuel
Check out epartsreplacement.com and there is a video on there you can watch that talks about fuel line replacement. It is a very helpful video Tom. Good luck
Posted on Aug 07, 2011
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan 2025 Chainsaw fuel hoses have broke down and fell apart. I have new fuel line but do not know the hose routing. All I found in the tank was pieces of hose and the filter. Only one hole coming out...
Aug 07, 2011 | Poulan Pro Chain Saw 46cc 20"
Jun 24, 2011 | Poulan Garden
Diagram of fuel lines from tank to primer to carb and back to tank for a poulan 2050 chainsaw.
clip_image002.gifFuel components are onthe "Engine Assembly" & "Handle, Chassis, & BarAssembly" detail pages.
Replacement fuel lines can be found at yourlocal chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Feb 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Jun 16, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Fuel line digram
Fuel systen components part numbers and a little detial can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
A helpful video, a few of my suggestions and a typical fuel system follow:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly.
HTH Lou
Nov 18, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
How do I install fuel lines on a poulan chain saw model 1950?From carburator to primer,from primer to fuel tank,two connections on each.
The smaller line comes from the fuel filter in the tank to the nipple on the side of the carb with the cover w/ 1large screw in the center, the other small line goes from the other nipple on the carb to the primer bulb, the larger line goes from the other nipple on the primer bulb back to the tank, and only gets pushed in about 1/2-3/4" into the tank. Hope this helps.
Feb 26, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Walbro wt hose routing on poulan saw
Carb has 2 nipples. top nipple gets line with filter on it from tank, bottom nipple receives line from bulb other side of bulb returns to tank
Jan 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
