Question about Dishwashers
One of the drawers is locked. How do I unlock it?
  • Michael Tarallo
    Michael Tarallo May 02, 2017
    Hi Natalie Harrington, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Fisher Paykel D603 f1 code top drawer only, bottom one has no power and locked
Check out I hope this is what you needed, and it works for you. Good luck!
Nov 07, 2014 | Dishwashers
The soap drawer won't open. Never had this issue before.
Is the machine a front loader? Is the drawer on the front of the machine? What is the Brand? I have a Samsung front loader and my detergent/bleach & softner drawer pulls out from the front. There are two drawer release locks on the drawer track (one on each side) if the drawer will give you any wiggle try pulling or pushing up gently. This may unlock the track. It sounds like the drawer was pushed in too hard... hope this helps
Oct 13, 2014 | Asko W660
Wascomat 16n4 front of drawer broke off. how can
I have a Wascomat W655CO,
This morning I got a screen message, Wait doors is locked?
I waited but the door never unlocked?
Oct 26, 2013 | Wascomat Parts Washing Machines
How do I replace the cabin air filter on my 2005 Toyota Matrix?
For 2005 Toyota Corolla (and Matrix), the location of the cabin air filter is inside of the drawer (passenger side). Open the drawer, you will see a screw on the RIGHT hand side. Unscrew it with a cross shape screw driver. Unlock the drawer from the screw holder. And take the drawer out of the cabin. After the removal, you will be able to see the location of the cabin air filter. There is a lock at each side of the filter cover. For each side, use two fingers to pinch the lock and pull out the cover. You will see the old filter after removing the cover. Pull it out, and insert your new filter.
Put the cover back. Make sure the two locks are firmly locked. Put the drawer back. To make this work easier, you may lock the bottom of the drawer first, as there are TWO locks on each side of the bottom drawer. Close the drawer to see if the position is right. Place the screw back, that's all
May 23, 2011 | Toyota Matrix Cars & Trucks
Can't get dvd drawer to open - has a lock symbol
On your remote there should be a unlock or seomthing that looks like a key if not in the menu system there should be. Please refer to your user manual if you do not knowhow to navigate the setup screens Thanks
Sep 23, 2009 | Televison & Video
ASKO 6021 washing machine, drawer locked
Reach under the drawer, right side and move the lock mechanism to he left. The drawer will unlock.
Mar 22, 2009 | Asko W6021 Front Load Washer
Bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Nov 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dishdraw DS603
look closely at hte display in theright corner is there a little icon that looks like a "lock". if so your control lock is on. do you get any response from any buttons??? if your able to power it up did you try to stop/andrestart unit. sounds like a silly question but sometimes the lid locks down from a power surge/interuption. restarting or canceling current cycle forced drawer to unlock and lock itself..assuming this is the top drawer is the bottom functioning ok??, behind the bottom drawer taped on back wall of inside of unit is atech sheet, with a pretty good troubleshooter. to remove the drawer push in rectangler hinge locks in hte bottom front corner of drawer front, just below the circles(no noeed to remove the circles)push themin and slide back the drawer will lift off and your able to set it aside(wont come out to far its connected by the hoses but itll come out enough(reset the door unto the hinge slides and pull hte lock latch foward to lock back into place
Mar 16, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Disk drawer is locked
You have to reset the unit: While stopped, press and hold [ ] on the unit and [S10/ENTER] on the remote control for about 3 seconds until ?Initialized? disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Sep 23, 2007 | Panasonic SC-HT95 System
Dishwashers Logo
Top Dishwashers Experts
