Question about Raypak Pool & Spa
My raypak spa heater does not cut off . once it is on it heats spa to 112 and when adjusting the light does not come on and no longer makes a click like the thermostat is not shutting the unit off.
    Sergeant:
  • 111 Answers
This is a thermostat or high limit switch issue - I had the same problem with my hot tub. It is a very common component to go bad. Have a serviceman look at it - but if you are savvy enough you could do it yourself.
Posted on May 02, 2017
    Diehard:
    Visited the website for 60 consecutive days.
  • 121 Answers
What model Raypak?
Posted on May 03, 2017
No Heat
The acid test would be to "jump it" and see if the heater functions normally. That's where you bypass the limit, taking it out of the loop. If you determine that the limit is the problem replace it, do not use the heater with the limit jumped.
Otherwise it may be the heating element itself. They do go out after a while.
Dec 14, 2013 | Raypak Spapak Electric Spa Heater -...
RayPac Pool heater won't light
check gas pressure too low it overheated replace fusible link on bottom after gas is fixed then clean heat exchange of soot
Apr 20, 2012 | Raypak 130,000 BTU Natural Gas Pool...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool & Spa Logo
41 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
