Question about Dishwashers
The indicator lights don't work on the upper drawer
The light on the drawer light panel buttons are not lighting up
Check the harness to the upper drawer for for broken wires, If broken you will need to replace the harness. But inspect carefully, as it could be in the middle of the harness were it bends. Good Luck
Jan 12, 2015 | KitchenAid Architect II KDDC24RV 24"...
Im having my changing table custom designed for me, how many drawers should I have, should I ask for shelves too?
I'm thinking no shelves since you don't want other people who walk into the room or even yourself see the mess that shelves may have, so drawers are the best way to hide a mess. I would also get 2 or 3 drawers, in the upper part, for the diapers and the rest just wide drawers all the way through. I would also consider having a corner changing table (if you have it custom made) it can save you some room and look really cool and special.
May 29, 2012 | Baby Gear
Frost in freezer
You can switch off the freezer from time to time to let the ice to melt.
Of course the too much accumulation of ice will affect the freezer.
Mar 17, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
When the paper drawer is fully-loaded and inserted properly, the "load paper" light blinks indicating that there is no paper (hence you cannot photocopy). However, when you pull the drawer out,...
if you remove the paper tray and you look in the slot that the paper tray slides in you should see a sensor flag hanging down remove the flag, it seems that the sensor is faulty the machine should work but wont let you know when the paper is finished so the very last page will show paper jam
Mar 18, 2011 | Toshiba 1370 Black and White Copier
Ge front loader leaks when filling
Leaks are probably going to come from one of 4 places:
  1. Door gasket: water should run down the face of the washer from the lowest point of the door.
  2. Water connectors: left rear of machine
  3. Soap drawer: water running down front of machine from the upper left-hand side
  4. Discharge pump and hoses: Right side.
Rear right would probably indicate a discharge hose leak. Front right would most likely be the discharge pump and/or connectors to it. Here's a diagram:
If you don't see any of the easily visible leaks (door, soap dispenser, connectors), try to
pop off the front access panel by removing the 3 bottom screws. Once removed try to determine where the leak is originating from...then we can troubleshoot more. If you find this advice helpful, please don't forget to rate me -- trying to get my Guru level so I can offer premium support
Jun 23, 2010 | General Electric WCVH6800J Front Load...
Lower drawer drains into upper drawer.
You are most likely correct,they tend to give out over time.
Aug 17, 2009 | Dishwashers
Saeco Magic De Luxe Espresso Machine Control Panel Doesn't Work
Do you have any of the left 3 lights on the top row? If you have the one that looks like 2 arrows pointing towards each other do this
Brew group missing indicator
Open the door on the right. Push on the upper left side of the brew unit until you hear a click. Close the door and see if the message is gone. If it is make sure that the grounds drawer is in place.
Tip: Pull the grounds drawer out, then push it back with only 1 finger and push it on the right side of the drawer. This will make sure that it engages the micro switch.
May 17, 2009 | Saeco Magic De Luxe Espresso Machine
Unable to get White Saeco Cuppacinno Machine to work.
Hi
I would say that your brew unit is not locked in.
May 04, 2009 | Saeco Magic De Luxe Espresso Machine
No response from control panel
Try this
Apr 17, 2009 | Saeco Magic De Luxe Espresso Machine
Error code c0500
open back coever then press reset switch from mainboard
Sep 26, 2008 | Minolta Di2510 All-In-One Laser Printer
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
