Question about Garden
Pto quit working replaced switch no help,hooked pto direct 12v worked.whatnow ?
    Master:
  • 347 Answers
You aren't getting 12v to the switch.
Posted on May 02, 2017
Model 50560X8 scotts lawnmower 20 horse Koehler engine with 50" deck. My pto shut off I replaced the pto switch and it worked for a minute before it quit working. Couldn't get it to start today either
Many when the battery is low or dead the PTO quits working .suggest recharging battery and see if it works then see how long the battery holds up but be prepared to replace it as none of the mower batteries have more than a 6 month warranty
Aug 18, 2015 | Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
I have a craftsman z7000 mower. When I engage the PTO the blades start working but after about a minute they stop, like I turned the switch off. I waited a minute and tried again, same thing, it worked...
something is loose, pto switch connectors maybe loose or corroded, wires at the pto, bolts on the pto there should be three of them. hope this helps Tim
Apr 24, 2011 | Garden
I have a Kubota TG1860 G riding mower. the blades have stopped engaging. I have replaced the push/pull switch, didn't work. It clicks like it wants to work but doesn't engage. What else can I do?
belts,solenoid,ignition switch and the PTO, you can hook 12v directly to PTO and see if it is engaging, the ignition switch feeds 12v to the PTO, the switch/solenoid engages with the help of the pulleys and belts, just a matter of figuring if its the belts(or in may cases the tesioner pulley) Hope this helped Tim
Apr 18, 2011 | Garden
My lawn tractor just quit running, battery fully charged, won't do anything when switch is turned on. Can the ignition switch be bad?
When you say it quit running, did it stop while you were mowing? Or did it just not start one day. Could be the ignition switch, but not likely. There are several safety switches on your mower. First is the operator present (switch in the seat) then there is the switch on the clutch that requires you to hold the clutch in when you start. Then there is a switch on the PTO for the deck that must be off to start. Without an exact model number, I can't look at the exact wiring schematic, but this is generally how they work. If you have a tester, and know how to use it start at the battery, look for 12 V. Then test from ground to one side of ignition swithch. Then to the other while the key is in start. Then find wires to seat switch. This switch should keep the mower from starting and keeps the pto engaged usually. then find the switch for the clutch/brake. test both sides of that. Finally test the small terminal on the starter solonoid. If you're getting 12V to the solonoid, and you have a good ground on your battery and it still won't start, could be the solonoid. If it actually quit while you were mowing, I'd check the seat switch and pto switch.
Jul 12, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Camry just quit running. I can't hear fuel pump,
The engines oil pressure switch has a third wire which is connected to the fuel pump. The oil pressure gauge may work although the third wire to the pump may be at fault causing your delimma
Once the engines oil pressure reached the normal operating range the computer shuts down the oil switches third wire to the pump and the relay takes over until you shut the emgine off
May 24, 2010 | 1998 Toyota Camry
Toro 265-6 model 72045 PTO clutch will not engage. PTO checked with 12V and works okay. Both relays checked and working okay. All fuses are good. Not sure how to check PTO switch. Any other suggestions on...
ohm out the clutch......should be 2-4 ohms any less means the clutch has an internal short and will need to be replaced. also check the saftey interlock module, however the modle numbers u gave do not come up, relays checked ok? how did u test them?
Nov 18, 2009 | Toro Lawn Mower With Toro Power Tools
Pto clutch keeps shutting off
If you have not replaced the pto switch do so. If you have check wiring from switch to the pto coil. Many times the wiring at the pto coil is rubbed by the belt until it wears the wire into. You can also try energizing the coil to the pto directly from battery (With engine off of course) If it energizes and stays energized it is probably not the coil.
May 03, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
