Question about Garden
Shear pin broken on my mower how do I change it
Fix shear pin on mower
    An user who is expert in 3 categories / brands.
  • Garden Master
  • 924 Answers
Take the tins of. take the nut that holds the flywheel on off and you will see the sheer key. if it is ok leave it alone. if it looks like the flywheel is not perfect with the crankshaft replace the key. it is some times hard to pop off but you can do it. go to you tube and watch a couple of videos on this process.
Posted on May 02, 2017
  • 30 Answers
SOURCE: shear pin ??
You most likely have several teeth broken off the drive gear that drives the cutting block. Not too difficult to replace but you need some special tools. A deep well socket (I think it's about a 3/8") to remove the cutting block and replace the broken gear. The gear should be available from a Fellowes dealer, or they might sell it to you direct if there is no dealer near you.
Let me know if this helps.
Bill Monroe
Posted on Oct 16, 2007
  • 81 Answers
SOURCE: Severed Shear Pin Poulan P35TN20SE
First and foremost check to see if the crankshaft was bent when you hit the culvert. Remove the spark plug, Tilt the mower on its side at a 45 degree angle and while someone slowly pulls the starter rope see if the shaft where the blade attachs wobbles. If it does then you will need to replace the crankshaft (which can be expensive in some models). If it isn't bent, then the shroud that covers the flywheel is removed along with the other parts in that area and a flywheel "knocker" is used to remove the flywheel. At this point the old key is visible and you can see if it is sheered or not, If it is, then reverse the directions just followed after replacing the flywheel key. Chances are 99% it isn't the key, but the crankshaft.
Posted on Jun 15, 2009
SOURCE: Broken shear pin in kitchenaid A9 Coffee Grinder
I was able to find 3/32 x 1/2 inch spring pins at a local hardware for 13 cents each. They may not last as long, but at the price I can replace as needed.
I also had to disassemble twice; I didn't notice that a portion of the old pin was wedged in the underside of the burr. When I put it back together the first time, the new pin rested on the old fragment and pressed the burrs too close together. On the coarsest possible setting, I got coffee powder!
Final note: The nut for the cap over the burrs is reverse-threaded...use a wrench on top, and a flat-blade screw driver in the slot at the bottom of the motor shaft.
Posted on Aug 11, 2009
  • 124 Answers
SOURCE: mower wont start , no compression when you turn
The shear pin might keep it from starting but it will not cause the low compression. More than likely the low compression is a stuck valve which is a job for a professional. Take it to a good servicing dealer for his advice and estimate. Sometimes there is a gasket or a valve problem and a good experience mechanic can tell a lot by just listening to the engine for a few seconds.
Posted on Sep 13, 2009
  • 11 Answers
SOURCE: blade shear pins broken how do I replace
Remove the spark plug.
Remove the blade retaining bolt, compression washer, and blade.
Most of the time the adapter just comes out.
Occasionally I have had to use a small hammer to tap it off of the shaft. Tap it in several places being careful not to damage the crankshaft.
A few, I have had to return the retaining bolt to the shaft leaving about a half inch between the bolt head and the adapter. I could then use a puller to remove the adapter. (WARNING! If you are not very careful, the puller can easily damage the retaining bolt and the crankshaft ruining the threads.)
NOTE: If you have a reliable slide puller, it's better to use that versus a compression puller.
Rarely have I had to cut the adapter away from the shaft. Only had to do that twice. (One was because the adapter and crank had corroded together, and the other the key sheered before the pins.)
Best of luck.
Posted on Sep 29, 2011
PB30 - 96025000300 (2011-01)
Check Belts as well as the shear pins in your pulleys .if the pulley turns but does not drive I suspect a shear pin has sheared off and needs replacing. The shear pin is inside the pulley and you need to remove the pulley to get to the pin.
Jun 23, 2016 | Garden
Have a zero turn lawn mower one blade won't turn why an how to fix it
Sounds like you have a broken shear the blade drive for that one side. Those shear pins are made to break if you hit something rather than breaking an expensive part. You have to pull the assembly off the shaft to get to it.
Jul 20, 2015 | Garden
Was cutting and stop moving forward and back wards belt in good condition
Could have broken the shear pin in the drive pulley. If one of the pulleys turns when you put it in gear but the other pulley does not turn then the shear pin is broken or missing.
Apr 04, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
While mowing the drive belt tightner spring broke. I bought a replacement but the blades will not engage. The drive belt has been routed properly. it seems as though the blade's drive shaft will not spin.
Check and see if the shear pin has broken. If the pulleys spin but not the blades then the shear pin in the pulley or shaft has broken.
Mar 30, 2015 | Garden
Right side of snowblower is constantly clogged with snow
Check the R.H. auger my guess is you have a shear pin that has broken and needs to be punched out and replaced. If it rotates freely (cleaned out of snow) then that's likely your problem. You can prove that by watching the shaft the auger is riding on if the shaft moves with the auger shear pins ok. If the auger moves seperate from the shaft the shear pin is at fault.
Feb 21, 2013 | Ariens Garden
Will shearing the Shear Pin on a push mower cause the rope to seize up as if it's locked?
a sheared pin will throw off the timing making it kick back when trying to start but what caused the pin ti shear ma have like a bent crankshaft
Mar 28, 2012 | Poulan "Poulan" Push Mower
I have a 5/22 2 stage MTD snowthrower and from behing the machine, the right side auger is not spinning. The left side works fine, when the engine is off, the right side spins freely while the left is...
your shear pin(s) are broken on that side they will look o.k. but are snapped off inside drive them out with a large nail or center-punch,don't use a regular bolt to replace the shear pin as they will fit,because if it gets plugged again the gearbox will be your next expensive shear pin to replace
Feb 24, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
I have an ariens 824 snowblower that needs shear pins. How to replace. Where to purchase them. I live in Hyannis Ma. Nick
Most times when a shear bolt/pin shears, the outer ends fall off into the snow, the inner part of the bolt stays inside the auger shaft. You must rotate the auger/ribon to find the hole in the shaft that has the bolt left in, and then with a drift punch, drive the bolt out of the shaft. Depending on the amount of rust, rotation may be difficult. Depending on the shear bolt, finding the internal broken part may also be difficult, but you should see a 'fresh metal shear' of the broken bolt. You can purchase them on eBay or your local lawn & garden dealer should be able to get them.
Dec 22, 2009 | Ariens Garden
Auger turning slow. Auger turns initially but auger stops turning when it hits the snow. Shear pins look ok, belt looks ok. Shear pins look intact. Could they be broken inside where I can't see.
sure sounds like a shear pin, usually one end will be missing if it is broke. They are simple to replace but get one that is rated for your machine to avoid damage. Can you turn it freely without the engine running?? if so, it's the shear pin
Dec 14, 2009 | Ariens Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
