Cuisinart cwc800 wine cellar stopped chilling, fan runs well but no chilling occurs
Before I toss this thing out, wondering if it is worth repairing
    Sergeant:
  • 111 Answers
You can get one on Amazon for $159 - service call and parts alone would be more than that.
cuisinart cwc800 wine cellar stopped chilling, fan - capture-s2yitbhs5ftb2bu2yvlx0or0-4-0_0.png
Amazon com Cuisinart CWC 800 8 Bottle Private Reserve Wine Cellar...
Posted on May 02, 2017
SOURCE: Cuisinart Private Reserve cwc-900 wine cellar stopped cooling
I also had one of these CWC 900 units that quit working. The interior temp was 77deg F and the outside was 70 deg F.
The exterior panel was very warm to the touch where the heat exchanger was.
Like a previous person stated, there are two fans. One on the control unit board and then the main cooling fan for the exchanger. In my case, this main cooling fan had quit working - allowing excess heat to build up.
Solution: Unplug the unit! Remove the side panel of the CWC 900. First remove the 8 "finishing" plastic plugs that hide the screws. This was done with a sharp point on an ice pick to pry them out. Then remove the 8 screws with a torx T10 driver. At this point, plug the unit in and lower the temperature setting. In my case the small fan kicked on and the larger one did not. Un plug the unit. If you try and manually turn the fa you will feel resistance. Remove the cooling fan and black housing w/ 4 phillips screws. seperate the wires from the cable ties and then unplug the fan - you may have to remove a small amount of a plastic type glue to unplug the fan. Remove the fan from the plastic housing w/ 2 phillips screws. This is a fan made in China and I was unable to find a replacement on the web. Remove the center sticker on the back with the fan model number. Remove the center black plastic plug with a sharp point. You will now see the end of the shaft and a small split keeper ring. This ring is made of plastic - be gentle. Pry it open and remove it from the shaft (KEEP IT). Once the keeper is removed, you will be able to pull and seperate the motor from the fan blade and expose the shaft. I was not able to remove the small bearing from the motor so I wipe the shaft clean, applied white lithium grease and the re-assembled the unit. Fan spun freely. Put everything back together and the unit should be fixed!
Hoped this helped.
Posted on Feb 14, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart Private Reserve wine cellar
It is normal. The goofy thing about this wine cellar is that once the ambient temperature is above 70 degrees - which is actually a low room temperature - the fan works constantly. You would have to make sure the wine cellar is in an area that stays below 68 degrees (brrrr) for it to shut off sometimes.
-Tha Mp3 Doctor
Posted on Mar 21, 2009
SOURCE: Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
  • 132 Answers
SOURCE: A couple weeks ago my
This is typical of a thermostat malfunction. the thermostat needs to be replaced
Posted on Apr 01, 2011
SOURCE: Fan doesn't work on oster wine cellar
The outside rear fan on my wine cellar seized and caused the unit to stop working. I replaced the fan with a close match (12vDC, 0.16amp) and the unit is working again. I also took the time to replace the in-line fuse in the upper left corner of the circuit board, just based on all of the blogs I read about it failing. I did all of this only becasue the unit was past it's warranty (>1year) I think however that the main problem with these wine cellars is that the two fans (one on outside, rear and one inside) are just too weak. They can easily be stalled if the air flow is blocked. Oster should have spent a little more money on a good fan and they might not have all of these dissappointed customers.
Posted on Mar 03, 2013
Why doesn't it cool?
If I unplug the Peltier the unit starts right up, the display working again and fans come on . Is Peltier shot ?
I also can't find the 4.5inch fans for unit Fan Model # SD1225S12L. What would happen if I leave Peltier unplugged ??
Dec 17, 2015 | Cuisinart CWC-1600 Private Reserve Wine...
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Frig won't chill. can hear it click off & on when plugged in.
HAVE YOU CHECKED THE SWITCH ON THE COMPRESSOR OR THE FUSE ? AND IF THE COMPRESSOR IS KICKING ON CAN YOU HEAR THE BLOWER FAN KICK ON ? IF ALL IS GOOD THEN YOU HAVE A BAD CONDENSOR THAT WILL BE THE NEXT THING TO CHECK
Apr 11, 2009 | Haier HVA052ALL-8S 52 Bottle Aficionado...
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
Koolspace 600 Problem
You'll need to replace the fan. The original fan bearings wear our after a couple of years. It's pretty simple to drill out the rivets and replace the fan. I suggest you replace all four with ball-bearing fan units.
Sep 19, 2008 | Vintage Keeper Koolspace Wine Cellar
-Tha Mp3 Doctor
Sep 13, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Bonjour wine cube #53372
The Bonjour Wine Cube Is NOT a refrigerator it has no freon it circulates air to keep wine stored at proper temperature for cellar. To chill place in fridge or get something with freon.
Nov 10, 2007 | Refrigerators
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
