I bought an aluminum awning model # 88-1379-6 and when i went to put it up there was no brackets to attach it to the wall. How can i purchase the brackets or where can i buy them?? it is a 12 x 10
  • 4 more comments
  • Jo-Ann Rhoden
    Jo-Ann Rhoden May 02, 2017
    there's no rail or instructions!!! is there anywhere i can get these?
  • Paul Katynski
    Paul Katynski May 02, 2017
    Obviously you purchased it used. They all pretty much assemble very easily. Is there a manufacturer anywhere stamped or a decal of any kind?
  • Jo-Ann Rhoden
    i bought from Winners and it was'nt used.
  • Paul Katynski
    http://members.gvasl.com/Pages/FAQs/csm/... You can try here for parts. Hope this helps you.
  • Jo-Ann Rhoden
    TY!!
  • Paul Katynski
    you are so welcome, good luck!!
    Master:
  • 347 Answers
Actually it should have had an entire rail that screws onto the fascia board and then the awning would screw to that.
Posted on May 02, 2017
Testimonial: "Thank You for your help Paul Katynski"
Fix awning to side curve of a bus
most caravan sales centres will have answers for you as this is what they handle
Jan 08, 2015 | Toyota Cars & Trucks
How can I make a ballet bar?
You can make a ballet bar in a few easy steps:-Purchase a bar-Purchase wall brackets-Measure and mark the space-Level the marks-Install wall anchors-Secure wall brackets-Attach the bar
Jul 09, 2012 | Dancing
How can I put. On my led tv on the wall
You need to purchase a wall bracket for your TV. There are several types on the market. Make sure the mountind holes on the TV line up with the wall bracket mounting holes and it can support the weight of your TV.
Google search for a wall mounting bracket for your model TV.
Nov 21, 2011 | Televison & Video
I have a PLTV-32CM flat screen TV that I purchased new in 2006. I want to mount it on the wall now and I have a wall mount that I purchased at the same time but never used. When I went to put it on, it...
Yes, it can be mounted on the wall mount bracket system. You may not have bought the universal adjustable mounting bracket type to match the VESA mounting dimension (the four monting holes spacing measured in mm).
See example here:
http://www.affordablehdtv.com/advanced_search_result.php?osCsid=3q5p8vevt3jbjuj19qc2mu4rr1&keywords=pltv-32&x=25&y=9
Please leave rating if it helps.
Jan 20, 2011 | Protron PLTV-32 Television
Looking for bottom mounting brackets for Coleman awning for my camper. It's a 12' long awning that pulls out on a winding tube. The arms that support it slip onto bottom mounting brackets on the camper. ...
Maybe these websites will help. The first one has a huge selection of parts. I am pretty sure you can find what you are looking for at one of these places. If they can't help you please let me know and I will keep looking. They are:
http://www.go-rv.com/coast/do/catalog/main?dealerId=66
http://www.marksrv.com/ultrahardware.htm
Aug 10, 2009 | Coleman Sport & Outdoor - Others
We just purchased a used '99 Starcraft Field & Stream PUP. There were no instructions for setting up the awning. I need step-by-step ''how-to'' help since everything I've found says, ''raise support...
I had exact same problem on my 93 popup. I finally figured it out. First, the poles with the plastic rings slide into the poles with the metal rings. These are the vertical support poles. Next, the poles w/ plastic nipples slide into the other poles with rubber ends. When put together the poles with the nipples should be spring loaded. These spring loaded poles rest against the top of the camper and the nipples are inserted into the 3 holes of the pole that go across the front of the awning giving you rafter support. The tension from the spring should keep the pole in place against the side of the camper. The first 3 poles with the plastic rings go from the ground to the front awning pole where the nipples can slide through the plastic ring and then into the awning pole. The vertical poles can be adjusted for height by sliding them up or down and then twisting them like a screw to tighten them up and keep them in place. 2 of my 3 vertical poles will not lock when I twist them so I have to get tricky with them. The metal rings, which should now be at the ground, are there so that you can stake it down under windy conditions. I hope this wasn't too confusing but I beleive it will help you. Good luck!!!
May 14, 2009 | Sport & Outdoor - Others
Wall mount dyna glo model RMC-40NGT
I have the same one i am looking for the wall brackets, I lost mine. I also bought mine at a garage sale the people had it attached to the wall completely hooked up .they had no fire backer on it .They only took it off the wall when i purchased it
Nov 02, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Awning fixed to existing brick retaining wall
If I were you, I'd use the threaded rod imbedded about 100mm in the wall. Make sure you have at least 5 threads showing after you tighten down the nut on the threaded rod. That will help you decide on the length of the rod. Make sure you use epoxy to hold the threaded rod in place and everything will be fine. However, if a big enough wind comes by, the awning may come loose from your house. Have you thought about a retractable awning? It will roll up next to your house. You only have to unroll it and connect the legs in prepositioned holders. During a storm, you probably won't be outside anyways, better to have the awning rolled up for safety.
Oct 28, 2008 | Measuring Tools & Sensors
Side rails
I have a similar problem, but a different Simmons crib. I called the company that momof4girls unrecommended and they were VERY helpful, but they were not able to ship me the parts as Simmons discontinued this type of hardware in the early 90's. My crib has a headboard and footboard - the 2 side boards are able to slide up and down on aluminum slats (almost 3 feet long.) The aluminum slats are connected to the headboards with 8 bolts; what I needed to order replacements of are the plastic sliders that allow the sidewalls to go up and down on the aluminum bracket. Not only do they allow it to go up and down, but without them you are not able to assemble the sidewalls to the crib at all. I solved the issue buy purchasing L brackets at Lowes and permanently attaching the sidewalls to the headboard and footboard, but it made it so the sidewalls did not raise or lower. I am ok with that! However, if you do NOT have the aluminum slats, you may be out of luck. The spring for the bed attaches on the aluminum brackets, so even if you were able to bolt the 4 sides together, you still have to figure out a way to attach the spring for the mattress (which connects by sliding a hook into holes on the aluminum bracket... no room for bolts here.) I am rather surprised that the hardware for this crib is plastic and aluminum; the bed is HEAVY and it is very difficult to put together as the aluminum slider is easily bent and the plastic sliders are flimsy. I actually broke the plastic pieces during assembly. No wonder this hardware was discontinued! I called Simmons and asked if they had an "updating' kit... they do not. Good luck!
Aug 25, 2008 | Bassett Baby Gear
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
