Question about Garden
My black decker 32cm 1200 mower motor working blade moving
Black decker mower motor work ln blade not going round
SOURCE: black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
Posted on May 23, 2008
  • 313 Answers
SOURCE: Can't start my mm525 black and decker electric mower
checked out dewaltservicenet for further info.
maybe a broken switch our possible broken armature comm
Posted on May 29, 2008
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
rowdy45176
  • 2176 Answers
SOURCE: can not get a blade on the Black & Decker Navigator SC500
Go to Dewaltservicenet.com and in the middle of the page at the bottom find the looking for manual box type in your model number and on the next page click on the instruction manual section for this tool, it is 4 pages long but it does reference removal and installation of the blade. If I have answered your problem would you please rate my response accordingly and thank you.
Posted on May 18, 2009
SOURCE: BLack and decker electric lawn mower blaDE IS loose and not turn
If it's like mine (MM 875), it has a plastic "clutch" that has little edges on it that broke off when I was chopping sticks with the mower ;-) Went to the local B&D place and got a new one for less than $3.
But now I'm worrying about the nut holding the blade on -- if I try to get it good and tight, the plastic "clutch" spins around off-kilter... Funny how I never even looked at the blade after I bought the mower used, but never worried about the blade being loose and flying off.
Posted on Sep 29, 2009
Black and decker electric mower hums but blade does not turn. appears the brake is not releasing for the blade.
Something has the motor unable to turn. Do not turn on till you locate the source of the problem lest you burn it out.
Aug 02, 2016 | Black and Decker USA Black & Decker MM1800...
Hi the blades on my E-drive 1200w lawnmower are not turning?
Sounds like you have lost or broken your shear pin out of your drive pulley. Make sure your drive belt is working the way it should be. You did not say if its working.
Mar 19, 2015 | Garden
Black and decker lawn hog 18 was working fine last time used but will not start now what,s the problem
while unplugged rotate the blade a few spins to move the brushes if there stuck make sure the outlet is good and try another power cord
Aug 13, 2012 | Black & Decker Black and Decker Mm575 18"...
I have a Black and Decker 17" Hedge Trimmer
id check the electric motor first, was it whining when it was going? like maby the brushes in the motor are worn out. if so u can maby get replacements
Mar 22, 2011 | Black & Decker 17 in Hedge Trimmer
Electric mower will not work
the shear pin has broke on the drive shaft put a new one in.
Apr 28, 2009 | Black & Decker 19" Electric Lawnhog...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
