Question about Ovens
I have the error message STOP on my Bauknecht oven - what should I do?
  • 8,088 Answers
Stop
Posted on May 02, 2017
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
We just plugged in our oven and it has E005 Communication error popping on the screen. Any ideas?
1. Turn the clock selector knob to OFF
2. Tweak the oven control by turning the clock selector knob slightly to the left (counter clockwise).
This may stop the popping message.
Thanks
May 31, 2010 | Bosch HBN5650UC Electric Double Oven
How do i reset my bauknecht oven clock?
This is what worked for me:
1) hold down the "Select" button for 5 seconds till the display starts flashing
2) use the right hand dial to set the hour
3) press the "Select" button
4) use the right hand dial to set the minutes
5) press the "Select" button
Mar 20, 2010 | Whirlpool GBS277PDS Electric Single Oven
Bauknecht Mod. BSC 1000 nothing working. Checked fuses - is there a switch/fuse on the oven that could have blown?
THERE IS A THERMAL SWITCH ON THE OVEN INSIDE FOLLOW THE POWER CABLE TO THE CONTROL SWITCH. MOST OVENS HAVE A THERMAL SAFETY INSIDE THEM INCASE THEY GET TO HOT
Mar 08, 2010 | Baumatic B187 Stainless Steel Electric...
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
GE: E Profile Single Electric Oven Model: JSP40W0WJWW
First press and hold the cancel/off button for 10 seconds.
If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
The 2 thermal switches are located on top of the oven behind the control panel.
Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
Kenmore gas oven
after the gas stove have been on a while a loud whoosh that is a constant thing comes on. I thought it was getting ready to explode. I took seconds after we turned the gas off for the noise to stop. Any ideas what this coud be
Jan 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven won't stay on and give an F error message
Disconnect the power. Disconnect the sensor harness from the control. Measure the sensor resistance (white leads). The resistance should be 1080 ohms at room temp. If the sensor is open the resistance is usually over 2900 and you get an F3 message. If the sensor is shorted the resistance is usually less than 950 ohms and you get an F4 error message. Also look for damaged harness terminals if not a bad sensor.
Aug 31, 2007 | Ovens
Ovens Logo
71 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
