No picture on my WD-52525 projection television.
The lamp light blinked red, so I purchased a brand new lamp. After installing the lamp, after a minute or so after powering back up, the lamp blinks red again. What else can it be?
  • 8,617 Answers
Chances are youre getting a 34 errod which is cxaused by failed capacitors on the power board. You can get the V26 DLP Power board repair kit at the following link which contains the capacitors and the CD with detailed instructions.
http://www.tvrepairworld.com/
Posted on Jul 25, 2009
Flashing lamp light on mitsubishi 52525
The lamp cover is not installed properly or the lamp door switch isnt working thats what causes the 32 error.
Apr 08, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Red "lamp" light was on
t is more than likely your television has had a lamp failure. Part number 915P020010 is the right part for your tv. Remove the lamp, your instruction book will tell you where it's located. Check the anode of the lamp, if fracture find a lamp on ebay vendors. Try niosales.com They are my trusted vendor for new lamps.
Jul 11, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My Mitsu 52525 lamp indicator went solid red. I
sounds like the caps on the power board have failed. You can get the V26 DM/Power repair kit from www.tvrepairworld.com which also contains the instructions.
May 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Thats usually caused by failed capacitors on the power board. The V26 power repair kit from www.tvrepairworld.com should repair that issue. The kit comes with the instructions on Cd.
Mar 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Turned on TV and had no picture. Now when I reset I get green blinking light then solid green status. After about 30 seconded red lamp light comes on. Is there a solution?
Your lamp is defective, incorrectly installed, or the cooling fan under the lamp is not cooling the lamp for some reason. Service that area.
Jun 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced lamp, no picture, turns to red light
please make sure to place Lamp Door/ Cover after installation of new Lamp in TV.
Jun 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Red blinking light
If the red lights comes on and stays on, you will need to replace the lamp. However, if the red light blinks repeatedly, your internal motherboard was either fried during a recent power surge, or the circut board will need recalibrating. In short, you will need to contact a cert. technician to re-initialize your set. It may be more cost-efficient to purchase new flat-screen plasma set. Good luck with your investment.
Jan 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed ctechnicians.com and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
