Question about Video Game Consoles & Games
Hush abye my little guitar - Video Game Consoles & Games
Where is the passenger footwell hush panel on 1997 pontiac bonneville
hush panel...that would be either the panel that covers the underside of the dash, or the so-called kick panel on the side of the footwell-a small panel that is in front of the passenger door. It's a trim piece that covers the chassis metal. A hush panel implies noise suppression, so I think it would cover the underside of the dash.
Dec 07, 2017 | Pontiac Cars & Trucks
Hey Dennis I have a 99 Jetta 2.0L with 4 speed auto. The problem im having is its going into limp home mode and I keep getting DTC P0758 wich is shift silniod B
I know that the jetta has a coolant migration problem from the sensor and it screws around with everything electrical and send all kinds of stupid codes check at the rad trust me I had to get rid of mine it drove me nuts. If the car goes to vw they will fix it. I have a personal friend that works there and they know all about it. But its hush hush don't tell the customer policy. Look into there website and do a little investigation about the issue.
Nov 13, 2012 | Cars & Trucks
Removing hush panel on 2011 dodge journey
These 'found' answers from previous solutions are way off! I am looking at the (interior) fuses on a 2012 Journey.... the hush panel you mention is indeed tough to remove, but it is not necessary. The fuse box is to the right of it, in an opening cut into the hush panel. It is a SMALL unit! You can access two plastic locks on it. The bigger, easier one to reach is to remove the whole box from its holder. To just remove only the cover, press the little middle button on the smaller, left latch. Actually, tho inconvenient to reach, it is easy to take off the cover without tools. I hope this helps, and the this info form a 2012 applies to your car.
May 26, 2012 | 2011 Dodge Journey
Where can i buy the soft crepe half sole and heel for earl and how much cost approx. thanks ron
hi
i think you can apporach the showroom which deals with hush puppies to get it or check out this site
http://www.zappos.com/hush-puppies-earl-black-suede
If you are satisfied with my answer please vote three thumbs up.Thank you
Nov 10, 2010 | Hush Puppies Earl SlipOn Shoes for Men
Where is the turn signal flasher located at on a 1991 corvette
Hope you are ready and limber...take out the hush pad under the passenger side (the plastic piece above where the passenger sticks their legs) Slide on your back and look directly upward along side the information center (where the radio and AC vents are) You will see the little round bugger up there. Get a long screwdriver and pop it out of the C clamp (spring type) You will have just enough wire to pull it down and change the flasher. Then try to pop it back into the clamp and button the hush pad up.
Oct 16, 2010 | Chevrolet Corvette Cars & Trucks
O.k. I have guitar hero III and world tour with two wireless guitars and controllers. One guitar works perfect the other won't recognize? flashes green but console will not recognize.
OK mate what you need to do is, theres a little button just right of memory slot B on your xbox 360 press that and at the same time (making sure the guitars on) hold down the little round button near the bit where yuo put the headset in and hold it down until the xbox picks it up :)
Aug 06, 2009 | Ubi Soft Video Game Consoles & Games
Where does the guitar controller plug into the xbox 360. I don't see a plug like it anywhere on the xbox console. I have the guitar hero III. With the guitar model number 95157.805
If you look on the front of your 360 way down at the bottom you will see a little door at the bottom, push the little flap in towards the system and you will see two usb ports, plug it in there.
Jul 30, 2009 | Activision Guitar Hero X-Plorer Controller...
When trying to link wireless guitar to x-box 360 all four green connection lights come on the guitar
press the connection finder button the little black button on the **** of the guitar then press the little white button on the front of your x box if you already knew that i appologize but i tried anyway.
Jul 30, 2009 | Microsoft Xbox 360 Controller
Video Game Consoles & Games Logo
54 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
